Question about Western Digital Passport 120GB External USB 2.0 Portable Hard Drive - Green
Theres no such slider or switch.., just the usb connection.., what should i do? can it be because of a virus or something like that?
  • Daniel Rodriguez Nov 11, 2010
    What is your issue? What are you trying to do?
  • Travis Lord
    Travis Lord Nov 11, 2010
    What is this slider / switch supposed to do?
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
Samsung YP-U2J Mp3 Player is Locked. How can i Unlock it? When i press On button, Locked screen appears.
My samsung YP-U2 has HOld on it when i turn it on,when it lights up theres a lock piture showing ,can enyone help me with this,please,cant get to play my songs,
Feb 10, 2011 | Samsung YP-U2 MP3 Player
My pen drive is not formated due to write protection
There is either a switch or a slider on the unit.
Set the switch/slider to "write-protect-off" to enable files to be written to the pen-drive.
Oct 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Acer 4930 bluetooth not switching on
There is a slider for turning on the bluetooth for most of the acer laptops. So make sure you've turned that 'slider' to ON.
Try looking around in the Control Panel. The "classic view" might help you find exactly where it is located.
These computers can be made with Bluetooth, but it is still an option, so you may or may not have it. If you don't, small USB adapters are available anywhere that sells electronics (Target, Wal-Mart) for about $20 if you really need it. Bluetooth is slower than a direct USB connection, so if its not too much of an inconvenience, a direct USB connection might work better anyway.
Regardless, here are the instructions I found for installing a Bluetooth device on your laptop:
To install a Bluetooth enabled device:
a. Set up the device so that your computer can find it. To do this, you must:
i. Turn the device on.
ii. Make it discoverable.
b. Click the Start button Picture of the Start button, click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
c. Click Add, and then follow the instructions.
Apr 20, 2010 | Acer Aspire 4930-6862 Laptop
Wireless on my Dell Latitude E6400 switched off and I can not turn it back on. Any idea?
Press on F2 when turning back the laptop by going to the BIOS setup screen and from there have to enable your WIRELESS CONNECTION. And then have to manually TURN ON your WIRELESS device by enabling or turning ON the Wireless button of the laptop. Thank you.
Apr 11, 2010 | Dell Latitude E6400 Laptop
YP-U2J Samsung mp3
just start mashing buttons....this happened to me and after a moment of panic...it worked!
Nov 20, 2007 | Samsung YP-U2X Digital Media Player
ROLLER BRUSHES WON'T ENGAGE
THESE BRUSHROLLS HAVE A RUBBER PAD WHICH IS CALLED A CLUTCH PAD. THIS MAY BE WORN, OR THE SLIDERS MAY JUST NEED A SMALL WASHER WHICH YOU CAN GET FROM YOUR LOCAL RICCAR DEALER. ALWAYS MAKE SURE YOUR LINKAGE ROD IS CONNECTED PROPERLY. ROD SHOULD BE ON THE BOTTOM PLATE SIDE, IF YOU HAVE THE MACHINE TURNED OVER WITH THE BOTTOM PLATE OFF IT SHOULD BE ON TOP OF THE BRUSHROLL.
Oct 27, 2006 | Riccar 8955 Upright Vacuum
Western Digital Passport 120GB External USB 2.0 Portable Hard Drive - Green Logo
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
