Question about Altec Lansing VS2121 Computer Speakers
One of the speakers is not working. This is the one that leads into the other speaker which has the on/off control. Sound is coming from the other speaker and the main box speaker.
2 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: no sound
see if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Posted on Jan 09, 2008
How do I factory reset my Casio CTK-2400 Keyboard?
You manual is here http://support.casio.com/storage/en/manual/pdf/EN/008/Web_CTK2400-ES-1A_EN.pdf
Interestingly...check out page EN-34...about the section on local control...Follow the directions to turn your sound back up... Good luck
Feb 23, 2015 | Casio Music
Hi, only 2 speakers work and the sub woofer also
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 21, 2011 | Logitech Z-680 Computer Speakers
Hi My speakers are acting up. Sometimes sound comes out sometimes it doesnt. Sometimes only sound comes out of the sub but theres no sound coming from the speakers. So i hear only bass. When i try...
if you are having problems with your sound
also
hope this helps
Apr 03, 2011 | Altec Lansing MX5021 Computer Speakers
Why is my left speaker coming out with no sound, but my right speaker (no controls on it) is working? To note, when I move the cord that plugs into the sound source, I hear crackling in the left speaker...
is the cord you move laying on a rug or carpet this will cause static
try swapping the speakers around if the problem still persists either the speaker is faulty or
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or click start control panel administrive tools computer management device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 23, 2011 | Juster AC-691 Computer Speakers
Left speaker is not working on my 2.1 speaker system...
A few things can cause this to happen. First we should check the computer. Take a pair of headphones or other speak set and check if sound comes from both sides. If to then the computer output is correct, else the computer is channeled to output to one side.
To change sound settings, if this is windows, go to your control panel and look for sounds option. In there you can change speaker settings, change volumes. On the volume control you can balance the speaker output. center the slider to make both correct.
If sound is coming from the PC correctly with a test object you will need to check your speakers for a fade option, not many have this it is just a suggestion. If no fade option exists, make sure the plug is totally seated. Improperly seated plugs will cause only 1 channel to be outputted or none.
If all the above does not help then check the cabled leading form the computer to speakers for damage as well as checking the wire between the left and right speakers for damage. Many times the output lead from the right to he left gets damaged from stress or other things and will stop output. Wiggle and pull the wire gently in each direction if they don't physically look damaged to see if sound is produced. if it is then the wire is internally damaged or loose from the speaker.
good luck
Mar 14, 2010 | Altec Lansing Audio Players & Recorders
Sound is coming out of only one speaker, with both wires plugged in
have same problem - swapped speaker leads and sound comes out of other speaker
Feb 12, 2010 | Bose Companion 3 Series II Multimedia...
No sound conning out of speakers from wharfdale mixer
Speakers are working OK otherwise?
Do you get sound from headphone jack?
It's probably some pot control not turned up.
Is MAIN OUT turned up
Are speakers connected to monitor out or main out.?
Is gain for mic turned up?
Is there a MAIN OUT switch (on/off)?
Is there a MUTE control on the board?
Aug 05, 2009 | Wharfedale Force One Main / Stereo Speaker
No sound
Try plugging in earphones to see if the problem is the speakers or the output from your computer. Also, your computer output may be low power output for powered speakers and your speakers are not compatable. You may also be plugged in to the wrong output on your computer.
JG in AZ
Apr 11, 2009 | Boston Acoustics BA7500 Computer Speakers
Surround sound not working through ordinary tv
Try connecting the red and white audio cords to your system from your cable box/satellite receiver instead of your tv. Worked for me.
Oct 01, 2007 | Audio Players & Recorders
Sound from all speakers problem
I would suspect the lead from your tv or video and swap this.ie where are you feeding tv signal to amp from.more than likely faulty lead or socket at this point.swap around the leads and see does fault transfer to the opposite channel.keep with it sounds like set up problem of some sort,.
May 18, 2007 | Sony HT-DDW750 System
Altec Lansing VS2121 Computer Speakers Logo
150 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
