Question about HP Photosmart C3180 All-In-One InkJet Printer
The alignment ont the screen for post card printing with word is just right. it prints with perfect alignment on regular paper, but when i put the post card in the printer it is too far to the right or the left.
    Scholar:
  • 61 Answers
IN Word have you changed the paper type / size to post card?
Should be - File. Paper setup, or on a newer version of office click the on page layout on the top toolbar.
Posted on Nov 11, 2010
HP 3n1 keeps printing out a
This happens regularly in some models when the alignment of paper is not done correctly. If the cartridge does not have a good print quality, the scanner can not correctly read the alignment and alignment repeated several times until you get it right.
Check the alignment with cartridges in excellent condition.
Feb 28, 2012 | HP Photosmart C3180 All-In-One InkJet...
How to print small envelopes on HP 7780
Here are a few tips for printing card:
  • Print a test print on regular paper. Before you use your special paper stock, print on regular paper to make sure your settings are right and there is no problem with your design.
  • Check the alignment. First, you can hold the test print up alongside the pre-cut business card paper and see if it is correctly aligned. If the alignment is incorrect, check the application you are using for alignment tools that can correct the issue. You might have to reconfigure these settings a few times to get the alignment you are looking for..
  • Set "Page Scaling" to "None" when you print. If you are using a Windows computer to print from a template or a PDF generated by business card software, the default setting can cause the entire sheet of cards to be scaled to a smaller size, causing the cards to progressively misalign as they go down the page. Once you click print, check in the preferences pane of the print dialog box that comes up. If page scaling is set to Fit to Page or a similar setting, change it to None .
  • Check the margins. If the design on your template goes closer than one half inch (12.7 mm) to the edge of your page, then you should look for the option on your print preferences dialog box that allows your printer to print the maximum possible area. Usually you will find this option either in page-setup, or as one of the options that are available after you choose Print from the File menu in the window that pops up. The exact location of this option can vary based on your printer type and driver.
Tip: If the program you are using is not giving you the results you want, try another program or an online resource.
Aug 12, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
My HP Deskjt F4280 will not print Avery injet 08371 business cards. I tryed the other number on the cards, 5371. Neither of them will line up proper. If I print on a blank paper it is printed correct. ...
you realy cannot print with that paper the ink cannot penetrate through, i have an experience here before and tried it on epson it print perfectly
Aug 07, 2011 | Office Equipment & Supplies
Do I need a special paper for this printer?
no not necessarily. I suggest you align your printer tray in such a way that it will instantly insert the paper and print it successfully. Otherwise the problem is maybe the unit itself or the drivers..
Mar 09, 2011 | Dell Inkjet 720 Printer
HP Photosmart C4795. Can't get business cards to align correctly at top. Alignment is perfect on plain paper, but starts too high on card stock so every one is lined up wrong. What am I doing wrong? Using...
In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
Jan 05, 2010 | Office Equipment & Supplies
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Avery label printing alignment issues. Please Help!
you may need to use some free software that is available for 10.4 and 10.5 users. produced by avery it is the DESIGN PRO available for download at http://www.avery.com/avery/en_us/Templates-&-Software/Software/Avery-DesignPro-for-Mac.htm
also available for PC
a bit awkward to learn, it does the advertised job
Jul 30, 2009 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
The 3eBK head stopped printing.
Try below some steps which might help you resolve the problem.
Print Head Cleaning / Head Refreshing If the printed Nozzle Check Pattern is broken, missing, or a specific color is not printed, clean the print head.
  1. Press the <Menu> button on the printers operation panel repeatedly until [MAINTENANCE] appears in the LCD.
  2. Press the left [<] or right [>] arrow buttons to select the cleaning setting you want. Select [HEAD CLEANING] or [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  3. Press the <OK> button.
  4. Print a Nozzle Check Pattern and perform at least two Head Refreshings if the pattern is not correct.
If this does not help, try removing the print head and then install it again. Once place, dont forget to aligh the head. Following are the steps:
Reseat Print Head Reseating the print head is seldomly needed to be done.
  1. Press the Open Button (1) to open the Paper Output Tray (2).
  2. Raise the Scanning Unit until it stops.
    1. Pull and hold the Scanning Unit Lever towards you, then raise the Scanning Unit.
    2. The Print Head Holder moves to the middle.
  3. Open the Inner Cover 1.
  4. Open the Inner Cover 2.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  5. Press the ink tank's tab (1), then remove it from the slot (2).
    IMPORTANT:
    Handle ink tanks carefully to avoid staining clothing or the surrounding area.
  6. Lift up the lock lever and take out the print head.
  7. Again, place the print head back in position and press down the lock lever.
  8. Insert the ink tank into the empty slot on the print head. Press down gently on the ink tank until an audible click is heard. Make sure the ink tank is in the correct slot.
    IMPORTANT:
    a. Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
    b. If the ink tank is inserted in the wrong slot, perform two head refreshings.
  9. Close the Inner Cover 2.
  10. Close the Inner Cover 1.
  11. Pull the Scanning Unit Lever towards you to close the Scanning Unit.
  12. Align the print head position after the print head is installed. You can align the print head position either automatically or manually. When automatic alignment does not work well, align the print head position manually.
Automatically Aligning The Print Head Position:
  1. Load A4-or letter-size plain paper in the paper support tray. Auto alignment cannot be performed when the Feed Switch is set to [CASSETTE].
  2. Press <Menu> repeatedly until [MAINTENANCE] appears.
  3. Press left or right arrow to select [AUTO HEAD ALIGN].
  4. Press <OK>. The print head position alignment pattern prints.
  5. Check the printed pattern. If the printed pattern matches the illustration, the print head position alignment is complete.
Manually Aligning The Print Head Position:
  1. Load A4- or letter-size plain paper in the paper support or cassette.
  2. Select the paper source with <Feed Switch> button.
  3. Press <Menu> repeatedly until [MAINTENANCE] appears.
  4. Use left or right arrow to select [ALIGN PRINT HEAD].
  5. Press <OK>. A horizontal pattern is printed.
  6. Beginning from column A on the printout, enter checkmarks in the patterns that have the most solid image.
    (1): Bad example (Least solid box)
    (2): Good example (Most solid box)
  7. Press left or right arrow to select the pattern number that you checked in column A on the printout in step 6.
    (A): Column
    (0): Select pattern number with most solid image
  8. Press <OK>.
  9. Repeat steps 7 and 8 to adjust columns B to L. When all the horizontal patterns are adjusted, you will be prompted to print a vertical pattern [PRINT VERT. PATTERN].
  10. Press left arrow. A vertical pattern is printed.
  11. Beginning from column M on the printout, enter checkmarks in the patterns that have the most solid image.
  12. Press left or right arrow to select the pattern number that you checked in column M on the printout in step 11.
  13. Press <OK>.
  14. Repeat steps 12 and 13 to adjust column N.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
