Question about Refrigerators
Wiring diagram for dometic refrigerator .troublshooting advice breakers reset ? thankyou
2 Suggested Answers
  • 253 Answers
SOURCE: Just had a new Dometic 2652 refrigerator installed
hi
may be ur wires are short circuited so call ur dealer
Posted on Jun 25, 2009
I need a wiring diagram for a dometic ndr 1092 eyebrow. specifically the humidity and frost switch
call 888-782-6665 they say they will help with their products and answer questions
Jul 25, 2016 | Dometic Refrigerators
How to reset refrigerator
It is a refrigerator not a circuit breaker.
If you adjust the thermostat to a cooler number and wait say 12 hours.
And it does not cool, the condenser may not be working or the unit has lost some/all refrigerant. (gas that is circulated and provides the cooling) . You can check the coils on the back and make sure these are clean. Call and investigate pricing to add the freon and check for leaks. Also have them see if the condensing unit may be the culprit if the refrigeration gas and oil are ok.
Hope this helps
Mar 27, 2014 | Dometic RM2652 Refrigerator
Don't have power to 120v recpt. on dometic rm 2862 ref
Go to your breaker box inside the RV. Locate the breaker that is for the refrigerator. It may have tripped but still looks as if it is on. Turn it off then back on. It should click and stay firm in the on position. Now check your outlet for power. Either use an outlet tester or a portable radio. If you have power but the refrigerator is still not working you will also need to check the 12vdc power supply. The refrigerator must have 12volts to operate even when in AC mode. There is a wire from the 12vdc connection block that goes to a thermal switch on the heat riser tube to the right. That wire has an inline diode and if the diode has failed it will not allow the refrigerator to work and like wise if the thermal switch has tripped it will shut the unit down. The switch is resettable. The diode wire, if bad, will have to be replaced. If you do not have 110vac power at the outlet after resetting the breaker you will need to remove the outlet and inspect it for bad connection or broken wire and then trace the wire back to the breaker box until you find the point of failure. You will also want to check the ground bar in the breaker box and make sure the neutral wires are properly seated and tight.
Sep 18, 2013 | Dometic Refrigerators
Wiring_Diagrams
Main wiring to fridge is just the 12 VDC to rear of fridge which should be marked where they connect. What other info are you looking for ?
Nov 07, 2011 | Dometic RM2652 Refrigerator
Dometic RM2862 Can you reset the thermo fuse? Current going to it but nothing going out and wouldn't this cause the unit not to work at all?
It probablby has a timer in it. You can reset the timer by turning it clockwise, and the compressor would come on again. It is usualy located under the concoles where the setting button is located. Look for a small hole under that console. If a thermal breaker is making the compressor cut off, it is usually located on the compressor where all the wiring are going in, along with the starting capacitor. Usually if the compressor is overheating and making the thermal breaker go off, there is a problem with the compressor, or it is low on refrigerant. A low refrigerant will make a compressor overheat. Furthermore if the compressor has been being overload by low refrigerant, it will be damaged sooner or later, by overheating the elecmotor inside and causing a short. If resetting the timer don't work and it is indeed the thermal breaker, unplug the machine and get it service, which I hope the compressor is still okay.
Jun 27, 2009 | Dometic RM2852 Refrigerator
WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Circut Breaker trips
  • i have no experience with RV units but if it were in a house i would suspect a bad breaker or a problem with the outlet itself. breakers  only trip when the wiring is gets hot.
  • unless it is a ground fault breaker (usually on the outlet) then this would trip if the flow of electricity is grounded. ground fault breakers do go bad often.
  • i think if the refrigerator itself had a problem then it would be consistent (as far as it is pulling amps anyway). not work fine sometimes and not others.
Jul 08, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
401 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
