Question about Karcher 1850 PSI Electric Pressure Washer Winduction
Power washer is leaking,from the union to the motor?
  • 7,733 Answers
Change it.Just Look at eReplacementParts.com and the parts diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
I cleaned my intex spa yesterday my spa is leaking by the pump everything everything else is working .
if leaking from front or top union see if seal ok if from between motor and housing replace whole unit if leaking ruining bearings and motor
May 24, 2018 | Intex Pool & Spa
Water heater pipes
1) Electrically bond pipes to ground to avoid stray current corrosion.
Use pex-lined di-electric nipples instead of dielectric unions.
Unions depend on rubber washer and will eventually leak and corrode.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#straycurrent
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#di-electric
http://www.thetankatwaterheaterrescue.com/forums/forum3/
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 15, 2013 | Water Heaters
Pump motor leaking at connections
take the pump unions off the motor and look inside them at the tailpiece. You should see one black rubber o-ring inside each one. Make sure they are seated properly in the grove on the tailpiece and reinstall.
If they appear to be flattened on one side you may want to get some new # 0-49 o-rings and change them.
Once they are seated properly your pump unions will no longer leak water.
Feb 12, 2011 | Jacuzzi 6800-959 Nova 6 Whirlpool Bath 6'-...
I have a GWL11 washer that has a small water leak that appears to be clean water. I looked underneath and couldn't see where it was coming from.
Sometimes water can leak from the hoses where they join the taps and/or the water inlet valves..Check for leaks by running you hands along the hoses and unions. Or there may be a problem inside the area behind the display panel...Unplug at wall and remove the 2 screws at rear of display panel. You may have to remove the lid by sliding it upwards while on the open (vertical) position..sometimes the mixer box leaks where the temperature sensor probe connects...Good luck...Nomess
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
How to fix a leak in the power steering 2003 kia sedona
If its a union tighten it a bit, if its a hole in a rusty pipe replace it. Any leaks at points other than unions are usually difficult to fix as the power steering fluid operates at high pressure. The only course of action is to replace the part. A leak can be highlighted by putting the steering to full lock either right or left and the pressure goes shooting up as the pump works its hardest
Apr 24, 2010 | 2003 Kia Sedona
Spin cycle not working
hi,
depending on the model, it may be that your plastic universal joint union has cracked and broken, they are replaceable. put the machine on its side and study the area in between the motor and the transmission. usually the motor has to come out and then the union is right there. dont forget to unplug it.
good luck
J
Jul 21, 2009 | Washing Machines
Spare parts for union petrol power washers
I am looking for a spare part for a union power pressure washer where do i find them?
May 04, 2009 | Garden
Karcher 1850 PSI Electric Pressure Washer Winduction Logo
239 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
