Question about ASUS M4A77TD Pro Motherboard AM3 AMD 770 ATX RAID SATA Gigabit LAN (90-MIB9S0-G0EAY00Z)
My pc does not boot when I install 2 ram modules on asus M4A77TD it only boots when I install 1 ram module I tried the other module alone and it worked fine so both of them are fine but they wont work together
    President:
  • 1,812 Answers
Please check the bus speed of the RAM witch one run perfect.After you use the same bus speed RAM in another moudle.
Posted on Nov 11, 2010
    Genius:
  • ASUS Master
  • 1,354 Answers
Hi
just go to Asus site from there check you motherboard how much RAM supports
if you have old M/B then it will not support more RAM
also check your OS which windows your using
4 x DIMM, Max. 16 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Due to OS limitation, when installing total memory of 4GB capacity or more,
Windows® 32-bit operation system may only recognize less than 3GB.
Install a 64-bit WindowsWindows® OS when you want to install 4GB or more memory on the motherboard.
*Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
  • 3,267 Answers
Install a 64-bit Windows OS when you want to install 4GB or more memory on the motherboard.
How to replace memory card slot in hp g60-230us
The 2nd RAM module maybe faulty or not compatible with the other RAM module.
Try to install RAM modules with the same specs from the same manufacturer.
Sep 10, 2012 | HP G60-230US Notebook
Repeating beep in my hp G60 laptop i changed ram but it didnt stop and but it stops when laptop loads windows
hi
repeat beeps is definitely a RAM module issue. ry reseating (installing) one RAM at a time... assuming you have two module sticks. try inserting one only, boot up system and see if it works without beep issue. if it doesnt beep, remove that module and reseat the second one alone. boot up system. if that one works as well, then these two modules are NOT the same maker, part number.
if they both work independantly, then the RAM together are not compatible. both RAM modules must be identical (maker, part number, etc) to avoid issues
hope this works.. please send me 4 thumbs up
Sep 18, 2011 | Lenovo ThinkCentre M58e Desktop Intel...
RK549AA-ABA SR2170NX problem: i think my second slot for ram is no good. i'm supposed to be able to install 2 gb max . I bought 1gb ram to install in slot # 2 but it doesn't work. can i install...
Is the 1Gb RAM you purchase the same make and speed as the original? If not, they may not be compatible with each other or the new RAM module may be faulty.
Try removing the RAM from slot 1 and insert the new 1Gb RAM module in slot and boot up your laptop to test the new 1GB RAM module.
Installing a single 2Gb RAM module should work.
Dec 29, 2010 | Computers & Internet
Laptop will not boot with new ram memory card
Those beeps are code for what is wrong,
go here to see what yours mean:
http://networking.ringofsaturn.com/PC/beep.php
Sep 05, 2009 | HP Pavilion dv6000z Notebook
Toshiba Satellite 1805-s253 memory upgrade
Usually this means it supports 512 mb of "Single sided" ram, which is rarer and more expensive... the usual ram you buy now is double-sided.. which will often only see one of the sides in older machines.
Mar 13, 2009 | Toshiba Satellite 1805-S253 Notebook
System failed to boot when installing additional 2X 1GB RAMs.
you need to place them on your motherboard where the memory is installed. Place in the order of one new, one old, one new, one old stick. that way they run in dual channel.
Oct 07, 2008 | ASUS M2N-E SLi Motherboard
Acer travelmate 2003lc will not boot with new ram
512MB (FT64MSD64V3F)
200 Pin Dimm - SDRAM - 2.5V - DDR - PC2700 (PC-333) - Non-ECC
is the correct type of RAM for your laptop.
Have you tried booting with all combinations.
512 in slot 1 --- Boots
move same dimm to slot 2 (on it's own) and try booting.
boot with 256mb in slot 1 and known to be good 512 in number 2
This laptop should allow up to 2GB RAM. So I don't belive it is an issue with the mother board not seeing the amout of RAM. I think it could either be flaky dimm or your slot 2 is damaged
Aug 23, 2008 | Acer TravelMate 2300 Notebook
Motherboard ASUS P5RD1-VM ram problem
More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
Feb 16, 2008 | ASUS P5RD1-VM Motherboard
ASUS M4A77TD Pro Motherboard AM3 AMD 770 ATX RAID SATA Gigabit LAN (90-MIB9S0-G0EAY00Z) Logo
248 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
