Bushnell PinSeeker 1500 20-5103 Rangefinder
Problem for Bushnell PinSeeker 1500 20-5103 Rangefinder
Will not give distances over
By rgiorgi147 on Jun 17, 2008
will not give distances over 130 yards
Same Problem
Nov 11, 2008
-   This is the second time this has happened to me.  Bought a replacement the first time thinking I just destroyed it.  This time I have been much more gentle, but in 4 months the same issue of no/slow reads on pins and no scanning possible.  This is crazy!  I can't go 6 weeks without a rangefinder.....anyone try to fix this on their own?-   dieselbolts
Sep 01, 2008
-   Yes, I have the same problem and for $399.00, pretty pissed off about this. My Pinseeker 1500 does not show distance eventhough the pin is clearly visible with no background. This is frustrating. It was working so good and considered it my best buy of the year. After 3 months, it stops working. Changed the battery and still has the same problem. -   Guest
Aug 13, 2008
-   Same problem in Norway. Gear 10 months old. thought it was the battery - but no. Tried two brand new batteries designed for heavy use. Problem still there. -   hallvardjaco
Jul 24, 2008
-   Me too!!! Is 2 1/2 years old and all of a sudden things farther than about 60 yards will not calculate.-   Guest
Jul 02, 2008
-   Same problem with my PinSeeker 1500. All of a sudden it either won't pick up the object or takes repeated attempts and then with sketchy results.-   golfatelkins
Best Solution
posted on Aug 06, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
According to Bushnell, the optical lense can come out of alignment. This can happen due to the unit getting bounced around during transport, shipping, in the golf cart etc... (If you gently drop it on the grass while trying hit your shot...)
The mis-alignment causes the longer distances to not work.
Bushnell suggest you send the unit in for re-alignment. The product comes with 2 year warranty and will cost only $10 of return in most cases to get it fixed. It takes about 3 to 6 weeks to complete the process.
Try this link for more info:
http://www.bushnell.com/customer_service/us_repair.cfm
Hope this helps.
Manny Bhakta
Popular Solutions for Bushnell PinSeeker 1500
Questions and Unsolved Problems for Bushnell PinSeeker 1500
Do you recommend Bushnell PinSeeker 1500 20-5103 Rangefinder?
Answer
Answer
Is it possible to get a parts break-down for my Bushnell Pin Seeker 1500 20-5103? When turning the... (More)
Answer
How do you clean sand out of your pin seeker? It was dropped along the cart path in an area of sand... (More)
Answer
The rangefinder appears to take a reading, the cross hairs show on the LCD display, but no yardage... (More)
Answer
My Pinseeker 1500 seems to have lost the ability to read anything outside of about 120 yds, even... (More)
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 27, 2008
I have the same problem with my 1500 rangefinder. It will not give me yardage over 150 yards.
Comment by arkie_37, posted on Jun 18, 2008
I am having the same problem with my 1500. Have tried 2 new batteries and it still will not consistantly pick up anything past 150 yards. Not even a house or building much less a flag pole. Anyone have ideas.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bushnell PinSeeker 1500...:
Top Rangefinder Experts
Rank: Guru Guru
Solutions: 3902
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Rangefinder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
