Question about Acer Aspire 3050-1733 Notebook
The screen all of a sudden stopped working. I closed it and put it down for a few seconds and after I opened the laptop back up, the screen was not working. I checked the little pin that turns the screen on and off for stand by but that was fine. I dont know what else to do.
  • Acer Master
  • 4,924 Answers
If this thing got to you after an update (automatic) it may be a driver error for the video card ..try to boot it up in the safe mode and roll back teh driver in the device ,manager ..or by restore system on start /accessories ..system tools/ system restore//
If you get something on screen when you start it ..but it blacks out when windows starts..this is the problem I just specified..If it is always black ..and never show a thing on it ..start it ..and look very carefully and see if you have shadows..if you do ..it means it is the inverter for the back-lights on the display and you need to change it ..usually this is about all it can go wrong unless it is a wiring issue ..(try also to flip it gently and see if it has contact issues..)
Posted on Jan 02, 2012
Older-model Toshiba TV shuts off by itself
There is a large sand filled resistor on the main board close to where the power cord attaches that cracks. This will stop power until it cools enough to make the connection then heats up rapidly to open it again. It may be worth the trouble if you're handy with a soldering gun and can get the back off the TV. If not then I'd consider getting a flat screen.
Aug 21, 2014 | Televison & Video
Sleep mode
Reinstall the Power management . Install the updated graphics drivers
Aug 07, 2013 | HP Compaq Presario CQ60-249US Notebook
My dell vostro 1014 laptop computer display driver stops working often and recovers automatically within few seconds, how to get it clear?
Try to download the latest driver and check the power saving options how long it takes the screen to turn off when the computer is not in use.
Nov 27, 2012 | Dell Vostro 1014 Laptop Computer
The screen is going black like its in sleep mode when i open it up
I had the same problem. While rebooting the laptop the screen would be on for a few seconds after it finished rebooting then the display would go black. If you looked very carefully at the screen you could see the image was there but there was no light behind the screen to make the image visible.
I removed the black plastic display bezel cover that goes around the edge of the display screen to check out the lights and wiring. I found a small magnet that belongs inside the display bezel had fallen out of it's slot in the plastic bezel and was stuck to the inverter pcb (printed cicuit board). To fix this problem I secured the magnet into it's slot inside the display bezel with a bit of glue. After fixing the problem and putting the display bezel back together the laptop worked normally.
This magnet is how the laptop knows the lid is closed. When the laptop is closed the magnet is moved closer to a magnetic switch on the inverter pcb and activates the switch. The laptop thinks it is closed and shuts off the lights behind the display screen. When the magnet fell out of it's slot and stuck to the inverter it activated the magnetic switch all the time whether the laptop was open or closed. This caused the laptop to think it was closed and shut off the lights behind the dispaly screen as soon as the reboot finished.
Jul 17, 2011 | Compaq Presario CQ61-310US Laptop
My compaq notebook presario cq50 210us is frozen on a black screen
Try the laptop on an external monitor, if it works ok on that, the fault lies with the laptop screen
If it does not work on that, the fault is with the graphics chip on the laptop
If it was working ok then suddenly died, check to see if you can boot to safe mode (F8)
repost the results
Jan 01, 2011 | HP Compaq Presario CQ50-210US Notebook
My Sony Vaio VGN FS630W turns on but noting shows on screen and looks like the hard drive is not loading. What should i do?
Your problem can be either a problem with the LCD connection or the laptop's suspend feature. Try this:
1. Close the LCD then open it again. Wait a few seconds and the screen should light back up if it is only a problem with the suspend feature.
2. If the above does not happen, do a hard shutdown by pressing on the power button for around 5 seconds. After it shuts down, turn it on again and the screen should light back up.
If the above does not work, seems you may need to have your laptop serviced.
NOTE: Please rate our help to keep this free service online.
Jan 09, 2010 | Sony VAIO VGN-FS630/W Notebook
PHILIPS DVD player 616K, how to change region or get into right region. my player was working OK. Suddenly it stopped functioning and showed/diplayed '' wrong region'' on the TV screen.
Changing the region code for DVD616K :
1. Press OPEN/CLOSE, and wait for the tray to open.
2. Use the remote control to input digital key '1', '1', '1', '0' in that order
if that dont work go 1, 1 1, 1 in that
order.
Kindly leave a few seconds between each entry, the microprocessor is slow
with these entries.
3. Press number '7', '8' or '9' to display the current region code of the DVD
player.
OR
4. Press any number of '0' to '6' to set the required region code. The OSD
will display the new region code of the DVD player.
5. Region '0' will be the setting for multi region
6. The region setting will be saved in the FLASH memory.
7. Press OPEN/CLOSE again, the DVD player will return to normal operation.
note: you want to chose region 0 so u can use all regions
Nov 15, 2009 | Computers & Internet
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
I recently replace the fan in my IBM Thinkpad R52. Ever since, when using the power cord it suddenly shuts down after booting for about 10 seconds. But if I use the battery it boots fine.
I would open the case back up to make sure nothing else got moved around when you installed the new fan. If it was close to where power plugs into the laptop, you might have knocked something loose that could be either stopping the fan and causing heat to shut you down, or causing a short when the fan varies its speed.
Mar 16, 2009 | IBM ThinkPad R52 Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Acer Aspire 3050-1733 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
