Question about Kenmore Dryers
Model # 417.91702000 Tumbler problem, will not turn anymore and makes loud noises.
Check that your bearings at the back of your dryer are ok, they might need greasing or replacing, also check your band hasn't stretched, or snapped
Posted on Nov 11, 2010
How to stop dryer from making loud noises and tumbler from hitting inside walls
A dryer kit contains the wheels that the drum turns on, new glides, to keep the drum in place, and a tension pulley for the belt. You may also need a rear bearing. I'd say about $60 in parts and an hour or two & you'd be good to go.
Dec 04, 2015 | Dryers
Dryer making loud vibrating noise
In all likelihood, the belt that runs the tumbler is loose, causing the tumbler to rotate off center. While it takes a few minutes, the front of the dryer should be removable and you can take the tumbler out and replace the belt.
Oct 11, 2014 | Amana Dryers
Ive changed the belt on my white knight tumble dryer CL 372 once put back together the drum won't turn and makes a loud noise
There are two do-nut shaped rollers that the tumbler rests on located behind the tumbler. One or both could be bad. Some models have a single "axle" in the center of the tumbler that may be causing the problem.
Oct 10, 2014 | Dryers
Maytag gas dryer makes loud rattling noise. Not a squeaking noise, but something between a rattle and a fast, rhythmic knocking. Tumbler works, heat works, but insane noise.
sounds like the drum isnt balanced. either make sure appliance is properly balanced on the floor or make sure you are not overfilling the tub.
May 24, 2011 | Maytag MDE8000 Dryer
Loud noise as the tumbler is drying
Front or rear? Rear is probably center bearing. Fornt is front tub wheel or glide worn out. If noise is in front remove front and inspect.
Jul 19, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
My dryer is making a loud squeaking noise when it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 27, 2009 | Dryers
I have a Neptune electric dryer model MDE4000ayw. The clothes keep getting stuck around the barrel as the dryer is operating. What is the problem? It also makes a very loud noise as it operates.
You need to disconnect the dryer from power source, open the unit, it sound like the drum has holes on it that stucked your clothes when turning. this problem common to all maytag dryers. The front support glide had chop up . You might likely change the drum or tumbler.
Comment if the solution solve your problem
Dec 06, 2009 | Maytag Dryers
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
How can i fix this problem ??
Turn the transfer belt by hand to check for any binding or noises. It could also be the fuser rollers causing the noise due to bad bearings since it sits above the transfer belt when it it closed into the machine.
Do you know how to remove the transfer belt to check?
Aug 19, 2008 | Ricoh Aficio 1035 Copier
Dryers Logo
61 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
