Question about Toshiba Computers & Internet
The FN key stopped working on my Toshiba Satellite 550L laptop when I installed Windows 7 (previously Vista). Now I cannot switch the touch pad on or off or do any of the other things shown on the function keys. I there a way of fixing this? Thanks Bill Critchley
bluegreenash
  • 661 Answers
SOURCE: Locked cursor on Toshiba Satellite using Windows Vista
you need to press f8 on boot when it is loading, to enter safe mode (before the Windows flash screen)
then when in "Safe mode" you can  should be able to gain access,
reboot from this mode and see if it loads normally,  if not then you have a configuration issue.
go back into safe mode, (login) and go to start>Run,  run a program called MSconfig,  this will allow you to look at your startup items,  and allow you to disable/enable them individually,
from this point you can diagnose which programs are causing your issues.
I hope this helps
Posted on Oct 11, 2007
sp4m771
  • 116 Answers
SOURCE: toshiba satellite fn key display problem
Just download this :) It will fix your problem. If it doesn't work, just search for Toshiba Value Added Package Vista/XP (that depends on what Operative System you've got) and download for your Operative System.
Posted on Jul 23, 2009
ilGreatLuigi
  • 47 Answers
SOURCE: FN keys not working
Search "flash cards" on your computer. Several shortcuts will popup and you shuld see one entitled "restart flash cards". Double-click on this icon and then hold down the fn key to verify if the restart worked.
Posted on Sep 28, 2009
SOURCE: FN key not working in Toshiba Satellite
Hey,
Try to install these utilies:
Toshiba Common Module
Toshiba Hotkey Utilities
Toshiba Touch Pad ON/Off Utilitiy
Toshiba Utilities.
... in the same order and reboot between them.
One guy posted it on some Forum.All credits to him :)
Hope it helps.
Posted on Mar 04, 2010
ask ask ask
  • 211 Answers
SOURCE: i m using fujitsu siemens
download the drivers!
Posted on Aug 17, 2010
I have a toshiba laptop satellite M305-s4815 ..... after removing windows vista and installing windows seven the scroll in the laptop touch pad had stopped working
Hi
Since you installed windows 7 have you been to the acer site to look for a new driver for your touch pad if not you may want to try a new one from acer enter make model and operating system
http://support.acer.com/
good luck
Nov 15, 2010 | Toshiba Satellite M305-S4815 Notebook
Touch pad problems
Most of the toshiba laptops can disable touch pad with FN + F9.
In F9 key u can find touch pad picture.
May 27, 2010 | Toshiba Laptop Keyboard for Satellite L10,...
TOUCH PAD ISN'T WORKING, CURSOR WON'T MOVE
your touchpad might have a 'lock' button nearby it, to enable or disable its sensitivity. this is usually helpful while typing, so you can disable it so that the when the touchpad gets touched, the mouse won't make any reaction. You can then enable it to work with the mouse. This button is usually either near the top border or near one of the four borders. Alternately, some laptops have a function key for touchpad enable-diable thing. It is usually Fn + F3. The function key (Fn) is near the Ctrl key. The touchpad key, in the in colour of the Fn key will be somewhere in the Function keys.
May 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
The touchpad stopped working after a powerpoint presentation i made. A friend helped me set up the laptop to the projector and he did press keys. Did he accidentally press some inactivating key in the...
FN + F9 should enable / disable the touchpad goto control panel - mouse - and see if you can change disable/enable touch pad from there Otherwise post back what windows version you have
Touchpads
you can enable and disable the touchpads Touchpad: - to enable or disable a touch pad/pointing device from the Start Menu > control panel > Change to classic view - {on left hand menu} click on the mouse icon Mouse Properties dialog box, click "Device Settings tab" select the device click to Enable or Disable OR You may need to enable in the bios/setup menu - as the PC boots - you should get a message on how to get into the bios/setup - usually using F2 or DEL Key or F10 see if touch pad needs to be enabled there OR one of the F keys may disable/enable - depends on the model of the Laptop - toshiba sometime use FN+F9 key
Apr 10, 2010 | Toshiba Satellite M55-S325 Notebook
Touches fn hors service
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Jul 14, 2009 | Toshiba Satellite A135-S2386 Notebook...
Frozen touch pad
Hold down the [Fn] key and then press the [F9] Key to toggle touchpad on and off
On my Toshiba Satellite 1135-S155 Fn key is in the middle of Control [Ctrl] and Alt [Alt]
Oct 02, 2008 | Toshiba Satellite 1135-S155 Notebook
Hey,
Toshiba Utilities.
Hope it helps.
Dec 03, 2007 | Computers & Internet
Computers & Internet Logo
426 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
