Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
I bought a used GE Nautilus portable dishwasher GSC3200. I was assured that it worked but it doesn't. The motor hums and it fills with water but thats it. No washing. No draining. Any ideas? Thank you
SOURCE: GE Dishwasher Problem
Here is a link with solutions that for the water draining issue. http://www.myhomestyle.info/how-to-repair-your-dishwasher/
Posted on Apr 26, 2008
SOURCE: GE Nautilus dishwasher wont run
getting ready to try what everyone suggests......wish me luck
Posted on Nov 11, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
whytfang
  • 170 Answers
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
Posted on Mar 28, 2009
whytfang
  • 170 Answers
SOURCE: GE Nautilus Dishwasher Start Problem (no water filling)
Model # should be on inside of tub wall....but any way...
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
My GE Nautilus portable dishwasher will take water in, the motor will hum for a few minutes and then drain out into the sink. This process repeats but the water never cycles inside to actually wash the...
Try manually adding water to the dishwasher. If it works then the water valve is just clogged. Sometimes it gets full of gunk and the machine will take in water but not enough to run properly. It is in the upside down cup shaped thing on the bottom left front. The other possibility is the Cam/Timer. It is in the door right behind the dial. This is the part that triggers all the different actions.
If when you add water it doesn't work then the valve or the solenoid on the pump assembly is likely done.
Feb 24, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
Need aerator connector for faucet on g e natilus portable dishwasher model gsc3200
You need this part#WD01X1447
Thanks for the question please rate me when you have a chance.
Have a great day!
Dec 11, 2010 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Connector to the faucet for GE Nautilus portable dishwasher
We just bought a used version of the GE Nautilus and we were able to get a generic "fits most portable dishwashers" adapter and it worked great. We went to Fred Meyer (which I believe is a Kroger company in the NW) and it was the only one they had. It only cost $3.99. The brand is Plumb Craft by Waxman and the model number is 76-127. Dishwasher Faucet Aerator. Hope this helps!
Good Luck!
Dec 27, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Nautilius not running
drain motor doesn't work, yo cn hear a little noise but maybe to hot, th motor doesn't turn.
Jun 29, 2008 | GE Nautilus 24" Built-in Dishwasher
Dish washer has no water.
Check the faucet first, turn off the faucet, disconnect the dishwasher copper hose, re-open the faucet and check you faucet see if there is water come out, sometimes there is a small stone or sand block the faucet. Good luck, hope this can help, if not we check the others.
Jun 16, 2008 | GE Nautilus 24" Built-in Dishwasher
Motor not running?
There is a pump motor underneath with an impeller that is most likely stuck. You will need to turn the impeller until it breaks loose if it is stuck. This is a common problem with GE dishwashers and I recommend that you run it at least once or twice a week to avoid this problem in the future, even if you have to run it empty.
Feb 27, 2008 | GE Nautilus 24" Built-in Dishwasher
if the dishwasher has not been used for a few weeks, the water in the sump that goes into the pump will evaporate causing the pump to freeze up. usually you can turn the fins inside the motor to free it up. make sure the dishwasher is not on when you do this.
Dec 05, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
254 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
