Question about Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard
Motherboard problem is not on but processor and fan are working perfectly
    President:
  • 1,812 Answers
Please tell display in running or not
Posted on Nov 11, 2010
  • shiboram sardar
    shiboram sardar Nov 11, 2010
    switch off pc open RAM cleane the RAM by erraser or ruber still it is not working ,again switch off the pc disclosed the battery wait for a while and start again
Dual core 2.8ghz processor not supported for intel 946gzis motherboard can u give me the suggestion ?
1) FOLLOW Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components of a computer.
Relieve your body of Static BEFORE working on your computer.
Computer on a table, computer Unplugged from power, computer case open;
TOUCH an unpainted surface of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
A Processor is the MOST susceptible hardware component to Static Shock.
2) Clean the top of the Processor, and bottom of the Heatsink THOROUGHLY.
Start with a plastic scraping device, (Old credit card?), and scrape off as much of the old Thermal Paste as you can.
If there is a Thermal Pad, carefully peel it off, throw it away. CANNOT be reused.
Scrape with the plastic scraper.
Follow with Q-tips dipped in Isopropyl Alcohol. (Rubbing alcohol)
91 percent is best, but 70 will do.
May take a LOT of alcohol dipped Q-tips as it's usually a gooey mess.
MUST be clean enough when you are done, that you could literally eat off of it.
CAUTION!!
Isopropyl Alcohol is EXTREMELY FLAMMABLE!
Use in a WELL ventilated area with NO sparks or flames present.
Thermal paste has to be PROPERLY applied.
NOTE about thermal paste that contains real silver.
(One example Artic Silver 5 )
Silver is an excellent conductor of heat. Will transfer the heat from the Processor to Heatsink very well.
Silver is also an excellent conductor of Electricity.
IF you apply too much it will ooze off of the Processor, once the Processor reaches operating temperature.
Will ooze onto the pins of the processor, or pins of the processor socket.
Will ooze down on solder joints.
Result is Short Circuit.
(If this has transpired, follow Anti-Static Precautions, remove Heatsink, and Processor, use alcohol dipped Q-tips to remove all thermal paste, start over. Sometimes you can get to it in time, and nothing is permanently damaged )
It is really best to install the Processor with the motherboard removed.
Reasoning is that you can hold the motherboard flat, up to your eyes, and look across it.
See if the Heatsink is sitting perfectly flat, or there is a crack of daylight showing in-between the Processor, and Heatsink
Heatsink on Processor MUST be sitting flat.
3) Watch power cable to Processor fan. I have had a few where one of the pin connections in the power cable's connector, pushed out a little.
Doing so meant the wire to that pin, was NOT plugged all the way in.
The pin in the power cable, did not plug all the way into the 'connector tube', of the Processor fan cable's connector.
('Connector tube' = Molex metal female terminal,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US )
This means the Processor fan will run intermittently, or not at all.
Result is overheating of the Processor.
4) Make sure the Processor fan wires are plugged into the motherboard.
Computer case open, computer turned on, watch the Processor fan. Make sure it is spinning, and seems to be spinning at the correct RPM's. (Revolutions Per Minute)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 19, 2012 | Intel Computers & Internet
My cpu fan vibrates. help me
There might be lot of dust accumulated on fan and heat sink. Clean it and see.
If it still vibrates replace with an approved CPU fan.
Jul 23, 2011 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
My gigabyte H55-S2M beeps continuously when running 3D graphics games (I have GTS 250 card). The Nvidia app says temperature is below 60c which is ok. The computer runs like this for hours, perfectly, no...
Hello
Check the CPU fan for proper operation. Check the case for proper air flow.Overheated CPU.
This is a heat related issue for the main processor.Clean the processor fan and heatsink area.
Also check the fan in your gts250 vid card for dirt or dust.I clean mine with a q tip.And a vacuum.
May 18, 2011 | Intel Motherboard
I brought a new Intel H55Tc Mother board, Core i3 Processor, 2GB DDR3 Ram. Now my system fan and smps fans spindling is not continue. But My SMPS is working well with other mother board.
Dear vijay, Please check your power ic of mother board there is problem. When you change it then your cpu and processor fan will be working.
Thanks. Rakesh.
Nov 26, 2010 | Intel H55TC Motherboard Core i5 650...
My pc frequently restarting anytime
It may be possible that your CPU is overheating and the BIOS restarts your computer for safety reasons.
You should open the tower and clean the inside of it. Unplug the cooler from the processor, clean the fan od the cooler, install new cooling paste on the processor and put them back.
It should work perfectly.
N.B: Do not change the BIOS settings.
If you need further assistance, leave a comment.
Cheers
Jun 08, 2010 | Intel D865GBF Motherboard
The motherboard not give any display !
last 2 things to do
1.remove the cmos battery
2.remove the cmos jumper.
remove power cable from power supply.
3.wait for 2 to 3 mins
4.put the jumper back to the correct position usually pin one and pin 2
5.try to start the mb if ok
ok
Nov 13, 2009 | ASUS P5N32-SLI Deluxe Motherboard
Processor fan
It sounds like your CPU fan is slowing down with age and thus triggering your motherboards warning 'slow fan' alarm, while it may just need a good clean (remove dust/grime) it may prove much easier to simply replace the whole fan anyway...
Jan 26, 2009 | Intel D101GGC Motherboard
My computer shutdown after 1 or 2 hours
unplug & remove cover and clean dust,dirt out with compressed air plug back in and try. check all cooling fans and make sure they are running if not check connections or replace with new one
Dec 18, 2008 | Biostar MCP6P-M2 Motherboard - v6.0,...
Computer
attached cabinet fan with your system. after that if the problem will not solve please change the processor fan.ok bye
from bhim, bankura
Sep 26, 2008 | Intel Motherboard
Cpu fan stopps
try to clear cmos with the jumper next to the mainboard battery
hit delete enter setup bios and save changes
chek if the main board is not in unapropriate contact with the metal case.
chek the fans power connector pins in the board
and finally make sure that ur power supply is functionong properly.
Nov 14, 2007 | Computers & Internet
Intel PENTIUM-4 865GV CHIP MOTHER BOARD (MBP4I65GV) Motherboard Logo
79 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
