Welcome to Fixya!
This is a known issue for PS3.
Please follow the instructions below, it worked for many of my friends who had the same issue.
If this the above does not work, try this:
Hope this helps. Please feel free to comeback if none of these work.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Make sure that the HDMI is FIRMLY connected to the TV and to the PS3. Nothing outrageous but HDMI cables need to be really pushed sometimes. Jiggle the cable slowly and see if pic will come out. If this is the case and if the PS3 is still under warranty, have it replaced.
Can you tell me what is the TV's brand and make? Is it on 480 or 720 settings (with PS3)?
Press and hold the power button again
until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Thanks, neither of these worked.
Firstly I tried the second solution so connect HD only to TV , change TV to HJD input channel and press and hold PS3 power button...nothinghappens , blank screen and PS£ turns onand then after about 10secs of holding it it turns itself off.
The second solution I went into the settngs in the ps3 (whilst connecting using the AV cables) changed it Hd, changed the TV input channel to HD pressed x and again nothing happened, blank screen. went back to the AV input channel and that was blank too.
Any other ideas or is it likely to be a problem with the graphics card/chip?
Thanks, tried this and tried m ultiple leads with no success. It's not under warranty
