I want to replace the old furnace in my house, I have two options: Fedders 95% Variable speed 2-stage or Tampstar 95% Multispeed Single-stage. Which is the best?.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 135 Answers
The 2-stage unit will give you better variable efficiency under differing temperature conditions than a single-stage would. If I had to choose I would pick the Fedders unit, between the 2 you listed. (I install HVAC components for a living...)
Posted on Nov 11, 2010
Furnace. Cycles on and off And onduring heat
If it is a newer high efficient furnace, some have what are called 2 stage burners and variable fan speed motors which will do this as to be efficient. If it is still very bothersom to you, have a qualified HVAC person look at it.
press the helpful button, check link below
Single Stage vs Two Stage Gas Burners
Jan 10, 2016 | Heating & Cooling
Tip
2 Stage Furnaces More Comfort and Save Money
Two stage hot air furnaces can save you money and make your high efficiency furnace even better. With your furnace running at low fire instead of cranking up to the highest heating output in mild weather you can be more comfortable while saving money.
Many people think that they are getting the best they can get by buying a high efficiency single stage furnace. What they often don’t realize is that they could do better yet and for a few dollars more have a high efficiency 2 stage furnace that could keep them much more comfortable.
There are 2 stage hot air furnaces that are now available that will only run at half fire if the full fire is not needed. With a two stage furnace in mild weather when only a little bit of heat is needed, the furnace will have longer run times on low fire. This will keep you room temperatures from getting too hot before the thermostat reacts and shuts the furnace off again. This will help to keep your temperatures from overshooting the set point and help to keep your home much more comfortable.
Many of these two stage furnaces also have variable speed blowers that run at a lower speed when heating on low fire. This will also help to save money on your electric bill, because these blowers use very little electric when running at these low speeds. Air noise from the blower running at a high speed is also reduced.
If you are thinking of replacing or installing a hot air furnace, make sure that you ask your contractor to give you a price on installing a two stage furnace. The price difference probably will not be much higher than a high efficiency single stage furnace. However the comfort of the two stage furnace coupled with the electric savings will make the extra money well worth it.
on Dec 14, 2009 | Heating & Cooling
Condensation water drips from top of unit
I WOULD CHECK THAT YOUR PVC PIPING IS SEALED PROPERLY.
Feb 22, 2015 | Goodman Manufacturing GMVC951155DX 95%...
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Amp fuse keeps blowing
The component being protected by the fuse is drawing excessive current - has to be a board or something because the motor always draws more than three amps. Check the units schematic for locating the possible offending board. Must be relatively new since you indicate it is multispeed. Still under warranty?
Feb 23, 2014 | Gibson KG7SA045C23A 45,000 BTU 80% Gas...
Furnace installation
LUXAIRE MAKES NICE REASONABLY PRICED FURNACES IF MAINTAINED PROPERLY WILL LAST A LONG TIME EFFICIENCY RATINGS UP TO 98% IN THE FULLY MODULATING MODEL. ALSO LOWEST PRICED CONDENSING SINGLE STAGE ,PSC FAN MOTOR 95.5 % EFFICIENT. THEN THE ONE THAT I INSTALL THE MOST BEST VALUE FOR YOUR DOLLAR THE 2 STAGE VARIABLE SPEED MODEL 96% EFFICIENT .THE FAN IN THIS UNIT SAVES AN AVERAGE OF $ 135 A YEAR COMPARED TO A REGULAR PSC TYPE FAN MOTOR. BEEN INSTALLING LUXAIRE FOR OVER 25 YEARS AND HAVE HAD GREAT RELIABILITY FROM THEM.
Nov 05, 2013 | Heating & Cooling
I have a E2EB-017HA air handler and I want to change it to a variable speed motor. Is this possible
Some companies do sell a variable speed kit. It includes the motor and controls. Get your model and serial number of your unit and contact your local Payne dealer. The can locate the proper kit if available for you.
Feb 03, 2013 | Intertherm E3EB-017H Furnace 17Kw 2
I'm considering installing a Goodman LP Gas Furnace:sizing? Ops?
Gerge, if you go to website www.energycodes.gov
you can do a heat load calc yourself. Basically, you figure out the sizes of walls, total area of glass. total doors to outside, ceiling area and types of building materials used. It is pretty easy and then you will know for sure. The contractor should be suppling you with one but if not use this, it is free!
Nov 03, 2009 | Goodman GMS90703BXA Heater
I have a Trane a/c that is 2 years old , a 16xli with variable speed and since it has been installed it never seems to get enough air flow throughout the house , it seems like it stays in low speed is...
;Most variable speed furnaces have dip switch setting on the circuit board that must be set to match the tonage of the a-c. there may be a diagram on the furnace door or in the installation manual.
Aug 26, 2009 | Heating & Cooling
We are look at purchasing a 95% Amana AMV9 furnace. What is the pro and cons on this unit furnace. Thanks for your help. Judy
the best furnace you can buy is a two-stage furnace with a variable speed blower, the most effecient furnace you can buy is the 95% one. the most important thing is the technician installing it. there is a very advanced setup configuration that needs to be followed depending on your outside unit, your ductwork, and the living environment. find a NATE certified dealer. also, look for a Lennox Premier Dealer, and an American Standard Customer Care dealer. you can find them by going to Lennox.com and AmericanStandardAir.com
Nov 12, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
139 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
