Hi i have a p4 SANSUI computer and am trying to get into the bios menu .. do you by any chance know how i may go about doing this
    Habit-Forming:
  • 106 Answers
Easy as 1 2 3 ok turn of pc when you turn ot on it will have a sansui logo page that won't stay for long press f2 or delete a few times and your in it will be either f2 or delete not both you may wish to press these buttons a few times.
hope this helps and good luck with the problem and by the way don't forget to vote for this solution.
Posted on Nov 11, 2010
Testimonial: "good info"
Boot up problem with Dell Precision 380 P4 Dual Core 3 GHz
Your computer is trying to boot from a floppy drive. Do you even have one? If not, then you need to go into the BIOS (set-up) menu and disable it. Be careful though, you could loose all your data on the computer if you make a wrong selection. As for an array message, you must have have a RAID disk configuration. That means you have 2 or more disk drives that mirror each other.
Mar 17, 2013 | Dell Precision 380 P4 Dual Core 3 GHz...
Computer not giving output to screen
Looks like a BiOS chip problem.
The bios on your board is the lifeline when starting your computer.
Pull out the bios chip and clean the contact points.Pull out the mem battery back up and flash the bios memory.Pull out all the hardware board on the PCi socket.
Put back the bios chip and flash jumper back after wards.
Restart......If BiOS shows up on screen you got a chance to revive the MoBo, if not.....Check the capacitors near the processor and look for any bloated caps. and replace it w/ the same value.
If no bloated caps.......... Sorry to say, you have to replace that board and upgrade to a higher type.
Hope that helps!
Dec 01, 2011 | Asrock P4I45GV...
I want upgrade my CPU from p4 520 to p4 660(2M L2 cache) on dimension 4700. I want to know if that will work on my pc. Right now i am operating on bios A05,and i want to know if i have to upgrade to bios...
For best results, you should run the Dell System Analyzer on your computer:
http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&cs=19&s=dhs&~ck=anavml&dgc=SM&cid=54281&lid=1472034
Updating the BIOS, while not difficult, is not usually recommended unless it will solve a problem. The reason for that is you must follow the instructions provided by the manufacturer exactly or you could render your computer useless.
If the Dell System Analyzer determines that you can upgrade to a P4 660, then go ahead and replace the P4 520. If the P4 660 doesn't work, then the best approach would be to re-install the P4 520, make sure the computer works, then update the BIOS after carefully reading and understanding all the instructions provided by Dell.
Sep 13, 2010 | Dell Dimension 4700 PC Desktop
Hi i have a p4x266e 8233 via board i had there a 1,7 intel celeron and i switched it for a 2,4 p4 whit HT and the pc is now running at only 1,2 GHz . The p4 is woring i know that for ...
You have hit the nail on the head.
Update your BIOS and that should sort the problem out. You can always go into the BIOS and set the clock speed of the processor providing the BIOS utility supports changing the clock speed.
Regards.
Nov 12, 2009 | Computers & Internet
Replaced 2.8 P4 with 2.4 SL6DV P4, still no video. Can't be the processor, two bad in a row? Does anyone have the list of compatible ram? Soyo is no more, at least their web presence is gone. I know this...
"Is there a necessity for the four prong power supply input or is it just for help with high draw cards like the AGP8?"
some motherboards have an optional power input, but i NEVER chance that. P4-AMD64 and newer had a 4pin power connector that actually provides power to the CPU
if your not getting video still i would point to bad mobo/gfx card/ram its one of them.
CPU's rarely fail anymore
Aug 07, 2009 | Computers & Internet
How to reset the bios p4 titan ga-8id533 motherboard
As the computer starts up hit the Del key, that will take you into the BIOS utility, once in the BIOS load optimized defaults, this will reset the BIOS configuration.
Failing this just remove the power cord from the back of the computer and take the motherboard battery out for 20 minutes, this will fully reset the BIOS so you will have to input the time and date.
Regards.
Jul 14, 2009 | Gigabyte GA-8ID533 Motherboard
Gateway laptop forgotten password operated by Windows Vista
Dear snmo7
You May be able to reset or turn off the password using your bios settings in dos mode.
To access your bios settings ,turn on your Laptop & hit the delete key repeatedly untill the bios settings menu is displayed.
Use the <-- --> arrow keys to scroll through menus and locate the Password options . You should have the option of reset/enable/disable the system/supervisor passwords..
Exit Bios saving the changes..
Jun 18, 2008 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
BIOS UPGARADES
i want all driver ibm laptop p4(m)
May 14, 2008 | Intel Motherboard
SL-86SPE-L Motherboard
This took ages to find... and EVEN LONGER to download, it felt like I was on pre-pre-pre-pre-56kbps era.
Anyway, without further ado:
Soltek SL-86SPE/SL-86SPE-L BIOS AM1.5L. Included:
  • Flashing App
  • How to
  • ROM file
86SPE-L15.zip
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Feb 17, 2008 | Soltek SL-86SPE2 Motherboard
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
