Question about Konica Minolta Bizhub-200 Minolta Printer
How reset factory default for bizhub c250 copiers?
5 Suggested Answers
SOURCE: Bizhub C250
Select separate scan in scan setting screen, select utilities, user settings, initial settings, current settings.
Posted on Mar 09, 2008
SOURCE: bizhub c250 error code
There are 4 things to try to reset any error codes on these machines
1.) open and close front door
if that fails go to number 2
2.) open front door and turn off main power switch and then turn back on and close front door.
if that fails go to number 3
3.) turn machine off and then turn back on while holding down the utility/counter button after a while a trouble reset box will appear on the screen press on the box and then restart the machine.
If this fails go to number 4
4.) failing all this call your local service agent.
Posted on Mar 10, 2008
SOURCE: Transfer unit Bizhub C250
reset life of actual transfer
Posted on Feb 14, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: I have a konica Minolta bizhub C250 and the screen
I can only tell you they are definately resettable as I do it all the time.
The fuser "fuse" is located in the connector wiring. Once you get the fuser out just look in the area where the large connector is. It is a very small fuse similar to a resistor, green, and is encased in shrink wrap.
The Transfer belt fuse is behind a small black cover. If you pull the transfer belt unit out of the machine about 6 inches, it is located on the front right corner. In other words standing in front of the copier with the belt unit partially out it is on the corner closest to you. You have to remove a screw, a c-clip, a small metal plate and the small black cover is held on with a very small phillips screw.
He is the parts availablitity and part number info.
Fuses are available at http://www.digikey.com/
Transfer Belts
Replace glass fuse 80ma , counter resets automatically.
Item # 507-1218-ND
Fuser Units
Fuse is wrapped in shrink wrap. Cut it out and splice in a 1/16 ma fuse.
Item # F2307-ND
Good Luck and Thank You for using Fixya.
Posted on Oct 08, 2010
Reset factory default
BIZHUB C250 GOTO
1)UTILITY/COUNTER
2)DETAILS
3)STOP ZERO ZERO STOP ZERO ONE
4)GO TO INITILIZATION RESET
SHUTDOWN RESTART
Mar 25, 2013 | Konica Minolta bizhub Office Equipment &...
Duplexing the second page is upside down
Incorrect setting :
1-Press UTILITY/COUNTER
2-On the display select, USER SETTING
3-Next select INITIAL SETTING
4-Next select FACTORY DEFAULT and push OK.
5-Next select CLOSE twice in order to exit.
Feb 08, 2011 | Konica Minolta bizhub C250 All-In-One...
Does Konica Minolta bizhub c250 All-in-One Laser printer have default password to go in Administrator mode?
yes, it have a default administrator password which is 8 times 0 (zero).if this does not work then try 12345678. best of luck.
Oct 08, 2010 | Konica Minolta bizhub C250 All-In-One...
How can I rest the admin password on Bizhub c250
still having trouble..if default password didnt work for you then try reseting it to default password by:
1) Utility/Counter
2) Details
3) press STOP zero zero + STOP zero one
and now your in Tech Mode
4) same page press STOP + Zero + C
5) modify admin password and retype and then exit
6) do not DO NOT touch any other options unless you know what your doing..you can lock the machine and would be able to work..rate if this helped you out
Feb 24, 2010 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Admin Password
Try 12345678.  That worked for me for my Bizhub C250.
Mar 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Colour selection Scan settings
Set up the copier to the settings you wish to use. In the Utility menue there is an area called "Default Setting" (?) selecting this will give you the current settings as default, here you can also reset to factory defaults
Jan 08, 2008 | Konica Minolta bizhub C250 All-In-One...
Resetting password
go to setup>and go to maintanance -->there is a option restore default>select that and after some time do power cycle>and rste me solved if its helps
Nov 15, 2007 | Konica Minolta bizhub C250 All-In-One...
Bizhub C250
In the Utility Menu you can set the default settings for most functions. Set the copier to the state you wish it to be in. Under the utility menu there is a default setting button. This will allow you to set the current state to the default as well as reset to factory default.
Feb 27, 2007 | Konica Minolta bizhub C250 All-In-One...
2,153 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
