Question about Radio Communications
I have i.oval 303 and forgot the pin number and cant pair, tried the defaults 0000 and 1234 with no joy is there any suggestions???
4 Suggested Answers
SOURCE: Pin number for philips SHB6100 aside from 0000.
yeah hedenram is right. my problem was that i was trying to pair something WITHOUT the headset in pairing mode. just switching it on doesnt put the headset in pairing mode and it will reject the 0000 passkey even if this is correct. it is vital when you turn on you hold the power button til it flashes red/green and then it will be in pairing mode and accept the 0000. the only way i found this was in the instruction booklet which i thought i had chucked away
Posted on Nov 27, 2008
funkyjacob
  • 76 Answers
SOURCE: Passcode/pin for my motorola bluetooth-H550
It has to be 0000 because no one can change it its set by motorola are you trying to pair with your phone?
Posted on Jul 07, 2008
SOURCE: bluetooth headset H12 pairing code
I just kepted trying the 0000 and it finally worked. Thanks for trying to help me. Debra
Posted on Jan 14, 2009
What is the pairing code?
The pairing code is a sort of a password that only the primary sender will have on their devise and this code in turn reflects unto the secondary receiver. Failure to insert this code within few seconds the devise will fail pairing and you have to start over again, switching bT on and off again.
Feb 12, 2014 | Itech i.Tech i.Oval 303 Bluetooth Headset
Cant unlock my phone i forgot my password
f you enter an incorrect PIN/PIN 2 three times in succession, the SIM card is blocked. To unblock it you need to enter your PUK/PUK2 (Personal Unblocking Key). The codes are supplied by your network operator. i would suggest trying default pins such as 1234 or 0000 then the next step would be to contact your network provider you can do going on the company website or looking for contact numbers with the information included in the box the phone came in
May 04, 2011 | Health & Beauty
I cannot get headset to stay on purple to pair it up with my phone, its fully charged and genuine headset but cant manage it.
when turning on your bluetooth device hold the power button down,for 8 to 10 seconds this usually puts the bluetooth inn pairing mode,then you have to enter a pin pairing code ,motorola and most other bluetooth manufactures use a 4 digit pin pairing code,motorola is as follows 0000,1234, and the others incase they dont work,are 9999,1111,try them in that order hope this helps
Mar 23, 2011 | Motorola Mobility H700 Wireless Headset
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
Plz tell me ho to restore my 1100 series mobile i have forgot my security code. the imei no. 35535200/626491/1
enter wrong passwords 15 times....it ll ask PUK number....now call ur customer care and as the puk number for ur phone number...they ll give u.....now just enter the puk n unlock the mobile... hope it helped u!!!!!!
Oct 12, 2009 | Nokia 1100
I forgot my unlock code (n76) how to unlock it?
Oct 12, 2009 | Nokia N76 Cellular Phone
Forgot password
if you have not set a personal code the default code is 0000,1234,or 9999 please rate the solution thanks
Sep 06, 2008 | Nokia N95 Cellular Phone
Radio Communications Logo
89 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
