Question about Cadence Exercise & Fitness
Hello! have a welso cadence m5 treadmill have a fault when starting it.belt tries to move then blows plug fuse.or trips house electrics any info would be appreciated kind regards l.harris
  • lespresley1 Nov 11, 2010
    Hello! javedghani1 thanks for your concern on the matter of my treadmill ive tried to start without the belt on!! and no knots or wraped over flex its a short flex.any other info out there greatly appreciated kind regards les
  • 42 Answers
Hi, firstly when ever you start the treadmill let it run free without you standing on top, give it a quick blast on max speed for 30sec or so. then stop it. never start the belt when your standing on top. the other thing to try is if you are using an extension wire unroll the whole thing.and last on the front of your machine at the bottom where the power cable goes in there should be a circuit breaker make sure this it switched on. and regards to the whole house power going off. in your main circuit board change to fuse to a higher amp/volt. hope i have helped.
Posted on Nov 11, 2010
Weslo Candence 5.9 won't run after being moved
Check for any loose electrical connections between control panel and motor especially any plug together connections. Moving may he have loosened or unplugged one of these connections. Hope this helps.
Dec 29, 2013 | Weslo Cadence G 5.9 Treadmill
Cadence welso 620 treadmill has no power when it is plugged into the electrical socket.
Check the circuit breaker. I was unable to find any info on this model. What is the model #??? WCTL?????
Dec 14, 2010 | Exercise & Fitness
I just moved my cadence 200cs treadmill, it was running when I moved it, Now I can not get it to move the belt., could it be the fuse and how do you take it out and look and what kind of fuse
hi
just look where power cable connects to the treadmill there is one fuse 15 amp it could poped just press it back
also check the console cable if you disassembled it
Nov 22, 2010 | Cadence Weslo 200cs Safety Key...
I have a Weslo Cadence M5 treadmill. When i used it, it tended to trip out the electrics when the treadmill was started, but worked when I put the trip switch back up again and tried again. However, it has...
hi, firstly change the fuse in the plug to a higher voltage, then if you are using an extention wire make sure all the wire is unrolled. i had the same problem with my m5. i was using an extention wire on a roll that was shorting out the trip on the treadmill and cutting the electric off. so just by putting a higher amp in the plug and i am now using a 2m extention alot safer and much better,
Nov 18, 2010 | Cadence Weslo 5.0A Treadmill Walking Belt
Is the Welso Cadence 927 Treadmill in miles or Km?
hi, the console can display speed and distance in either kilometers or miles!
step 1/ move the key and hold down the stop button.
step2/ reinsert the key into the console, after you hear a bleep tone release the stop button and an "m" for kilometers or an "e" for english miles will appear in the display. press the speed in-crease button to change the unit of measurement.
step 3/ when you have chosen the miles take the key off and reinsert it. hopefully you should have changed your units to whatever you have chosen.
Nov 08, 2010 | Cadence Weslo 927 Treadmill Walking Belt
NEED INSTRUCTION MANUALL FOR WELSO CANDANCE630 TREADMILL
Hi there. You can go here and enter the model number In the model number box and download a manual for free.
http://www.iconservice.com/CustomerService/manuals.do
The model number will be located on the lower frame under the belt assembly.
Good Luck, Tim
Aug 15, 2010 | Cadence Exercise & Fitness
Where can I find a free manual for a Weslo CT Pursuit 3.8R exercise bike?
Go to iconfitness.com click on to customer service then manuals put in manufacturer name Welso, the brand name CADENCE CT 4.8 and their 1 match for your unit.
Apr 25, 2010 | Weslo Cadence CT 4.8 Treadmill
Got a weslo cadence m5. on it for 15 minutes stopped completely. got electric working again by pressing trip switch on bottom. when i press go it try's to jolt a little but thats it. had a look underneath...
You know I have exactly the same problem..with mine jolt and nothing more. trieed it for 15 minutes then just stopped! have you found a solution yet!
Sep 23, 2009 | Cadence Exercise & Fitness
Exercise & Fitness Logo
229 people viewed this question
Top Cadence Exercise & Fitness Experts
Jim London
Jim London
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Cadence Exercise and Fitnes Expert? Answer questions, earn points and help others
