Question about Canon PIXMA MP620 All-In-One InkJet Printer
In front A4 paper tray I inserted smaller paper (same width but shorter length) and it has jammed somewhere in the printer. I've tried access the paper but can't find it - it must be inside the mechanism. What steps should I take to get access to the jammed paper?? Need answer ASAP !!! Thanks, Geoff (Australia)
  • worky47 Nov 11, 2010
    Yes ..... thank you ...... I followed your simple steps and easily retrieved the paper jam and then restarted the printer .... thanks heaps ..... Geoff from Oz
    President:
  • 1,961 Answers
Hi!
Try these steps: this works for others.
1. Extend the back paper holder all the way up. (this should uncover a long rectangular hole)
2. There is a plastic piece with 2 arrows pointing to the right on it (if you are looking at the back straight on). Simply push them to the Right and it will pop up on the Left side.
3. You can now lift that piece out and remove the misfed paper!
4. Reinsert back the rectangular piece after you have taken the misfed paper out.
If that did not help just post back.
Thanks
Alp
Posted on Nov 11, 2010
  • boston76777 Jan 07, 2011
    Thank You very much ALPUG!!!!!! these steps solved the problem pretty fast..... well done!!!!! It had drove me nuts already!!!!!
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
My printer is constantly jamming papers. What maybe the cause and how can I prevent or solve this?
Its possible the paper is not good for the printer or the internals are dirty. Check your printer physically and run the cleaning option and try again.
To avoid a jam:
  1. Use only one kind of paper at a time in your input tray.
  2. Whether you have a single input tray in your printer's driver or many input trays, tell the printer what kind of paper you have in the tray: Most printer controls include a section or drop-down list where you can pick a paper by name, type, thickness, or other quality.
  3. If you aren't sure whether your printer takes a certain kind of paper, check its documentation.
  4. When you reload your input tray, pay attention to the tray's needs, such as how the paper should be loaded and whether the length or width guides need adjusting.
Mar 09, 2015 | Samsung SCX 4623F - multifunction fax /...
On the top of the hp 2015 there is what looks like an 8 with like a sideways N next to it that keeps lighting up on my printer and inhibiting it from printing-- I don't have a manual to tell me what means.
Hello, The printer is indicating a Paper Jam.
Check the tray for proper paper loading, length and width. Check the rear exit, any paper back there? Check under the toner cartridge for loose papers.
1) Turn the printer off 2) Remove the main paper tray 3) look inside the hole in the printer from where the tray came out. You should see black rubber roller. paper dust can build up on this roller and cause the paper to slip. You can wipe this roller down with a water dampened lint free cloth, 4) Re-insert the tray, with paper in the tray. 6) Turn the power on to the printer. 7) Does the printer come ready? Print a test page.
For further information GOHERE
Feb 03, 2011 | HP LaserJet P2015 Printer
Feed jam
1) Be sure the paper tray is inserted all the way in.
2) Be sure you're using the right size of paper (width, length and thickness; paper that is too thick may jam a laser printer if it is not configured properly)
3) Be sure you're using the correct TYPE of paper. Paper designed for ink-jets sometimes produce paper jams on laser printers.
4) If the paper was jammed before, you may have a small piece of paper jammed in the printer rollers. Open the printer and very carefully look for small pieces of paper on the rollers and all the paper paths.
5) Also, some printers are very picky about how much paper you have in your paper trays. Place enough paper on the paper trays so that it is about 3/4 full, no more, no less.
6) The paper rollers that pick up the paper may be dirty with dust. Use a q-tip and 2 drops of rubbing alcohol to wipe the rollers clean. Rotate the rollers with your fingers to be sure that all the surface of the rollers are wiped clean. Be sure to use 91 % rubbing alcohol; carefully read the label of the alcohol and use the one that DOES NOT contain anything except rubbing or isopropyl alcohol and water, no glycerin or any other additives. Wait at least 1 hr before using the printer again to be sure that the alcohol has completely evaportaed .
Please, report back if you need further assistance.
Mar 31, 2010 | Samsung CLP 315 Laser Printer
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Feb 11, 2010 | HP LaserJet 4050 Printer
Paper jam every time you try to print
remove existing paper..check for black sensor. clean pickup roller
your question is as evasive as my answer.
Jul 09, 2009 | Dell 1700 Laser Printer
Paper jam
Some of the Ink Jets have a cover in the back of the printer that you have to turn a lock to remove and you could have some paper stuck back there.
Mar 03, 2009 | HP DeskJet 3940 InkJet Photo Printer
Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Feb 17, 2009 | HP LaserJet CP3505n Printer
Printing card
Postcards, 3-by-5 inch (index) cards, and other custom-sized media can be printed from tray 1. The minimum media size is 76 by 127 mm (3 by 5 inches) and the maximum media size is 216 by 356 mm (8.5 by 14 inches). Note You might experience some jams when using any media with a length less than 178 mm (7 inches). This might be caused by paper that has been affected by environmental conditions. For optimum performance, make sure you are storing and handling the paper correctly . Using media from another manufacturer might also help. Printing on odd sizes or weights of media (for example, small, long, or narrow paper) can decrease print speed. The decreased speed helps to prolong the life of internal printer parts. It also improves print quality with these types of media. Guidelines for printing on custom-sized media and cardstock Always insert the short-edge first into tray 1. If you want to print in landscape mode, make this selection through your software. Inserting paper long-edge first might cause a jam. Use the rear output bin to reduce curl. Do not print on media smaller than 76 mm (3 inches) wide or 127 mm (5 inches) long. In your software application, set margins at least 6.4 mm (0.25 inch) away from the edges of the media.
Aug 21, 2007 | HP LaserJet 2300dn Printer
Dell 1700n Laser Printer Jam trouble
If it?s always in the same spot then you can narrow your search for the problem. -Look where the leading edge of the paper is getting jammed up for an obstruction, especially if the paper is folded in an accordion fashion. Look closely, I?ve fixed many a paper jam by pulling out a corner of a page stuck in a recess. -If the paper path is clear then the next thing I would suspect is the paper you are using. -Try new paper that isn?t bowed, folded or curled. Before inserting into the paper try flex it back and forth along the width and length, then insert making sure to slide the two side guides and the back guide until they fit snugly against the stack of paper. -Other things to check are the rollers where the leading edge of the paper is getting stuck. Make sure they are clean. -Also make sure your toner cartridge is inserted into the printer correctly. If you have a spare try using that, sometimes cartridges can drag on the paper.
Feb 25, 2007 | Dell 1700n Laser Printer
Canon PIXMA MP620 All-In-One InkJet Printer Logo
579 people viewed this question
old marine
old marine
