Question about Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
Disk boot failure when I installed a new SATA DVD writer
Hi I have just purchased and installed a new NEC 7191S DVDRW SATA Lightscribe and when I boot up the AMD 64 Athalon 3200+ 2.2GHz 2.5 GB of RAM (Winfast K8S 755A) Windows XP SP3 my computer comes up with a Disk Boot failure. I have two hard drives installed as master and slave on the IDE slots. If I diconnect the SATA signal cable from the motherboard and boot up - It starts up fine. Looking at the User Manual for the motherboard it states "These connectors support the thin Serial ATA cables for primary internal storage devices". Does this mean that on boot up the BIOS selects SATA over IDE drives to load the programme? If so, is there a BIOS update that resolves this issue? If not then how do i resolve this issue? Thanks for your help
  • proba1003 Oct 03, 2008
    I got a new Sata dvd writer as well, i set it up in the bios to boot from the harddrive, but if the writer is plugged in, it would try to boot from there. if i unplug it, its all fine, if i plug it back in after, it would recognize the writer just fine. But restarting the system... i back where i was. Please help.
    President:
  • 2,351 Answers
Start the system & enter you're bios & use you're manual to help guide you on this. Go to the Boot section of the bios. You can set the boot order. Normal boot order is like this:
1st boot device, floppy disk (if one is connected).
2nd boot device, cdrom drive
3rd boot device, hard drive
(Drive the has windows installed on it).
Save & exit the bios. The system will restart & windows should load. If it does not, than you picked the wrong hard drive.
Mike
Posted on Jun 18, 2008
Can I play store bought dvds on my new memorex slim external cd/dvd writer? The box says yes but when I install, it just shows the movie name and won't do anything
If it is just a writer then no but I have never heard of just a writer and mostly they are designated a reader/writer when they should be able to read whatever they are capable of writing - if the computer has the right software installed that is.
It could be you need to instal a suitable media player or dvd player software.
Sep 05, 2016 | Memorex 32020019660 8X DVDRW External Slim...
Intel D102GGc2 shows disk read error when detached sata dvd writer and xp boot when attached the same
Hi. if you're getting the same 'disk read error' when the DVD drive is attached and detached, then the error relates to the hard disk, that you're supposedly trying to install XP onto.
Ultimately you want the board to boot the DVD drive first. A quick change to the 'Boot priority' in the BIOS should sort it.
Apr 27, 2014 | Intel Computers & Internet
Do I need sata or eide for internal dvd writer on HP a1330n?
This model HP has a SATA disk controller.
You need a SATA DVD writer.
If you are not sure, when you remove the faulty DVD writer, take it with you when you go to purchase a nre DVD writer, make sure the new DVD writer has the same connectors as the faulty DVD writer.
Jan 22, 2012 | HP Pavilion Media Center a1330n - AMD...
Reading and writing problem
Hi nveerapa2008
Your device is defective , unless you are not using the correct software .
Best regards ,
fanaudi .
Aug 20, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
When i put some dvd disk in the drive it does not read but the light in the front just blinks constantly
Is your DVD-writer not recognizing any disk? If it so, the most probable case is that your DVD-writer's Optical Lens has been corrupted. Go for another new DVD-writer or try repairing your DVD-writer.
Dec 24, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I am looking for a hp lightscribe dvd supermulti drive/cd writer that is compatable with a hp pavilion a720n desk top computer and all so a dvd/cd rom combo that is compatable with ...
Any brand-new CD/DVD reader/writer with LightScribe *WILL* be compatible with your HP.
Check whether your "power" and "data" cables are the "old" style (white power connector and a 80-pin ribbon-cable) or the "new" style (thin SATA cables), before you buy a writer with the "wrong" (PATA versus SATA) interface.
Sep 26, 2010 | HP Pavilion A720N PC Desktop
I have sata dvd writer.when i connect it my computer does not boot.does intel D102ggc2 supports sata dvd writer?
You're Intel motherboard does support up to 4 SATA hard disk drives including SATA CD-ROM / DVD-ROM drive, reader/writers. This MB also includes two serial ATA IDE ports.
The most likely reason you're system is not booting is because all SATA ports are all seen as Master drives. By connecting the SATA DVD-ROM drive the bios auto configured the SATA ports.
You'll need to enter the bios when you're system boots-up. Press the F2 key on you're keyboard right after hearing a single beep. You will than enter the bios main menu. Listed at the main menu are devices connect to the motherboard. (Instruction on how to move around in the bios is listed at the bottom of the screen). Mainly, the hard disk drive or (drives) and the SATA DVD writer. You'll need to open the Boot tab. Look for boot order. You want the boot order set like so;
First boot device: [Floppy disk] drive; if one is connected.
Second Boot device: [Primary Hard Disk] drive.
(The drive with windows installed on it). (This drive may be ATA IDE or SATA; you did not provide that information).
Third Boot device: [DVD-Rom] drive. Save and exit the bios. The system will auto restart.
You're windows operating system should load correctly after the auto re-start.
The SATA data cable and the SATA power cable should be checked for good connection. It only takes a little bump to make either loose.
Here is the link to Intel for you're motherboard;
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22+D102GGC2+%22
Mike
May 12, 2010 | Intel D102GGC2 Motherboard
Boot failure asus a7v 133 motherboard installed a pci sata raid
Hi whistler1410, you need to enter your bios menu. Press the delete key every couple of seconds to load the bios menu.
Once in the bios (See instructions located at the bottom of the menu, to help you move about).
You should see all connected drives at the main menu.
This includes the SATA writer & hard disk drives.
Go to the bios menu, BOOT.
SATA drive even DVD drives are seen by the bios as a master drive. So within the BOOT menu go to "Boot device priority".
The boot priority should read as follows.
First boot device [Floppy disk drive] (If one is connected)
Second boot device [Your SATA DVD writer]
Third boot device [Your primary hard disk drive] (The drive with windows loaded on it).
If you do not have a floppy disk drive than make the first boot device your DVD writer.
Save the bios & exit the bios. You should not receive "boot disk error message anymore".
Run into a problem, post here.
Good luck whistler1410!
Mike
Mar 25, 2009 | ASUS A7V133 Motherboard
Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard Logo
328 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
