Question about ADI Corporation MicroScan 5P (White) 17" CRT Monitor
I have a problem on my "ADI microscan M700" monitor .when i switch on it then i can see a bluesh colour ,sometimes it has no problem . When the fluctuation of power monitor goes to same problem
3 Suggested Answers
torresfvr
  • 69 Answers
SOURCE: adi microscan monitor 17 green screen
this is a loose cable from the monitor vga. please make sure the cable is secure from THE monitor side
It is a connection somewhere. It can be the cable, monitor, or video card. If you another input on the monitor i.e. DVI try that with a different cable. If there is another output on video card try that. Mix them to test. trial and error.
Odds are there are some smashed pins.
Posted on Jul 25, 2009
bhagyavichar
  • 414 Answers
SOURCE: ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Posted on Nov 11, 2009
Require driver for windows 7 64bit please
I have run into this issue a couple times recently with this exact model & a handfull of other various Monitor's , http://www.filefactory.com/file/cbc1b15/n/ADIMonitorV97.zip , here is a link to the drivers I used on Windows 7 64 bit Home Premium , I installed using compatibility mode ( right click the .exe , select properties from the drop down menu , select the compatibility tab , select run in " windows xp sp2 " mode & check the box at the bottom " run as administrator " . Also you might want to disable " UAC " ( open the control panel , select users , select change UAC settings , drag the slider all the way down to disable , then click apply & reboot your pc for it to take effect .
Apr 17, 2011 | ADI Corporation ProVista M700 (White) 17"...
ADI monitor , model 937g, power supply dead , fuse is ok ,what could be the problem ?
replace 100uF/63V condesator and check transistor
BUT12AF if this is ok? check resistor 470k ohm and 1.2M ohm if the value is correct
Feb 11, 2010 | ADI Corporation MicroScan 5P (White) 17"...
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
ADI Microscan repair manual
http://www.mediafire.com/file/taanzydizgi/adi schematics.rar
here I got some schemes for adi ..monitor ...and I also put a reader cause the files came in djvu file format ..I hope this is what you was looking for ...
I also located another repair manual but Im afraid is not free they do want a few bucks on download...I will put a link just in case...
http://www.spotbit.com/main/magazine.php?&prod=1721
Oct 07, 2009 | Computers & Internet
Adi microscan monitor 17 green screen
Jul 18, 2009 | Computers & Internet
Better/higher Colors for ADI CM900?
sounds like the CRT is on it's way out. open it up and check what brand the CRT is, if it's a samsung. chuck the monitor.
as good a manufacturer samsung are. they can't make a CRT display for S@#$
Apr 26, 2008 | ADI Corporation MicroScan M900 (White) 19"...
ADI A905, No Display, but appears to get signal
I have the same problems as you. I found the only fix is to physically unplug the monitor from the wall outlet, and then it plug back in. Sounds like an internal design flaw.
Oct 02, 2007 | ADI Corporation MicroScan A905 Black 19...
Laptop screen problem
I think that possibly over-heating may be the cause. try running a fan on the back side to keep it cooler
May 31, 2007 | Compaq Armada M700 Notebook
ADI Corporation MicroScan 5P (White) 17" CRT Monitor Logo
94 people viewed this question
Top ADI Corporation Computers & Internet Experts
Alun Cox
k24674
Are you an ADI Corporation Computer and Internet Expert? Answer questions, earn points and help others
