Question about Amana Heating & Cooling
I have an amana heat pump #RHE48A2A and need to know the size of the start capacitor for the compressor. i live in the country not accessible. can you help? thk tomt
    Novelist:
    Champion:
  • 230 Answers
The cap should be a 55/5/370
Posted on Jun 17, 2008
Bypassing thermostat on amana pth093a35ab
Hallo
I would highly recommend not doing that because the compressor won't know when to stop and then starts roughing liquid into the suction valve causing the compressor to stop pumping and a thermostat is much cheaper then the compressor but if you see the thermostat there's a Live going in, connect it with the out going Live and that would bypass the thermal switch.
Regards
Jun 23, 2016 | Amana Refrigerators
I have an amana heat pump a/c PTAC unit 14700 btu and it seems the compressor is not engaging or blowing cold air
could be a bad run capacitor or the unit needs to be cleaned take it outside and wash the condenser coil the outside coil and the evap coil on the inside be careful not to get the electric circuits inside the unit wet. I would wash the coils first and then see if it cools. Hope this helps
Aug 13, 2014 | Amana PTH123B25AJ Heat Pump Air...
Model PTC093B35AMBP .AC unit will not start., fan will not start.
The very first thing to check is the capacitor. If it looks swollen or leaky it probably has failed. 25795c3.jpg
When both fan and compressor won't work their is an excellent chance this is the problem. If that is ok the control would be next suspect. Since BOTH compressor and fan won't run you either have a capacitor or control switch malfunction. I am leaning towards the capacitor route. Let me know
Jul 06, 2010 | Amana PTH123B25AJ Heat Pump Air...
I have Amana heat pump, I dont know why it does
sounds like your resetting the compressor its going off on high head pressure. check and make sure the condensor coils are clean. and that the fan is running properly.
May 10, 2010 | Amana PTH123B25AJ Heat Pump Air...
Amana Ac compressor won't come on. Heat works fine. red light blinks once and code is normal. pth123a35
would suggest replacing the compressor capacitor first before going any further. The capacitor aids in the initial start up of the compressor and if it is bad the compressor will not start. The capacitor is located in the area behind the control switches and is usually gray in color and round. They may be oval and silver also. For this type unit I think the capacitor is a dual capacitor which means it also runs the fan. Note that the compressor side of the capacitor can be out and the fan still run. So before I would think about replacing the compressor I would replace the capacitor which is about 30 to 40 U.S.D.
Good luck hope this helped
Dave
Mar 30, 2010 | Amana PTH123B35AJ Air Conditioner
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
No heat
Your compressor sounds like isn't working? And the problem is if we are lucky you just lost the capacitor. turn off the breaker to the ac/heat pump unit. Open the electrical panel on condenser locate the capacitor if it is swelled up like puffed up can then for sure it is bad. It has two sides to the capacitor one for the fan and one for the compressor. If you have a meter check it in ohms. If you don't have a meter take the capacitor to a heating and air conditioning parts house and get a new one just like the one you have very important to get right size. let me know how it turns out. ken
Dec 20, 2008 | Carrier 38BRC048 Air Conditioner
Amana PTAC
I know this is late but I had to add a solution to this problem since I had the exact same problem and was able to solve it. The probelm is not your control board. On these units, the heat pump compressor will not kick in unless the temperature you set on the control panel is within 2-1/4 degrees (or 4 degrees depending on your unit model. Otherwise, the unit locks out the compressor until the electric heat coil bring the indoor temperature up to that level - and then will switch the compressor back on for heat pump operation. So the problem is not the control panel or the compressor, it the electric heat coil. The coil has two manual limit switches on it that may be tripped and should be checked. The coil can be easily accessed by shutting down the power, removing 4 screws around the air outlet, pushing the screen up and sliding the panel out the top. The power wires can remain in place while the limit switches are reset. Hope it works.
Nov 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Ruud heat pump capacitor size
A hard start or turbo 2000 will not work if the run capacitor is bad. You will need to contact a ruud supply house or dealer with model and serial to find out the exact match. I have checked my sources and came up empty handed. You could try getting a 35/5 MFD at 440V or a 45/5 MFD at 440V as these are the most common capacitors used in Rheem and Ruud equipment. The key is that you will need to check your amp draws on both motors against the nameplate rating to make sure that you are not over-amping the motor. Also check the nameplates on both of the motors. Most condenser fan motors and some compressors list the capacitor size they require in a somewhat less than conspicious location on the label.
Jun 26, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
