Question about LG GH22LS50 DVD-RAM Burner
Dvd will not display in mycomputer after operating system loading.It detects in bios but after booting the dvd will not display in mycomputer and system will not work
    President:
  • 1,812 Answers
Fit sata cable or pata cable again tightly or if you have another cable change it
Posted on Nov 11, 2010
HOW TO DETECT THE CD ROM USING PHOENIX ROM BIOS PLUS VERSION 1.10 A02
The BIOS information is typically found at or near the top of the POST screen for a very short time ALR PC non / PCI = CTRL+ALT+ESC AMD advanced micro devices=BIOS = DEL Award BIOS = DEL Dtk Datatech Enterprises Co. BIOS = ESC Phoenix BIOS = CTRL+ALT+S Phoenix BIOS = CTRL+ALT+INS Restart your computer during the boot process you will see on the screen to press a certain key usually Delete or F2 to enter setup
this will differ depending on which bios you have Press and hold that key during the boot up process to enter BIOS Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system (note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults) after windows has loaded your computer will automatically restart it might restart 2 times one to finish the installation the next will be because the operating system is loaded and will boot from your cd during the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart otherwise it will keep booting from the cd /dvd drive
If the cd rom is not being detected ?
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Feb 28, 2013 | Computers & Internet
Not boot from dvd
hope this helps you
Mar 15, 2012 | Gigabyte GA-6VXC7-4X-P Motherboard
I needed to change the hard disk of my computer. I installed the hard disk and tried to install the operating system which I have been using viz. windows XP pro. I inserted the operating system cd in the...
Hi
first go to the BIOS and check your Hard Disk is detected or not if it is detected then go to the boot section on your BIOS and set CD Room as a first boot device and HDD as a second...
or if your hard disk is not shown in the bios then check your hard disk reconnect power on you hard
disk.. and most important thing don't forget to check jumper setting of you hard disk...
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 06, 2011 | Computers & Internet
Why my computer the monitor dont display windows i can see only blinking negative sign and it was block out did i press wrong command or it is my computer have a virus?
Thank you for choosing Fixya. I think on what happened on your machine the Operating System Boot Menu is corrupted that's why you only have a black screen and blinking cursor on the upper left part of your display. I suggest try to isolate first the problem if its a Hardware or Software. First load to BIOS and check if the Hard Disk Drive(HDD) is detected, if happens that the HDD is detected try to reload the Operating System using the CD/DVD(OS) that comes with the machine.
Apr 22, 2011 | ASUS Eee 4G Notebook
My computer is displaying 'reboot and select boot device or insert boot media in selected boot device and press a key
If your computer give that message, means that you don't have a operatig system available for loading.
Your Hard Disk might not be detected or the operating system installed before was erased somehow.
Make sure that you have in BIOS the Hard Disk Drive set as Primary boot device or check if the HDD is detected in the first place. If not, make the corect setting then save your BIOS settings and reboot.
Nov 02, 2010 | Acer Aspire One PC Notebook
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
Format a dell latitude cs laptop
hi rashmi
first g o to bios setup and check your external dvd is detected .
If not detected in bios then enable legacy 2.0 in bios advanced option then go to boot option and save first as dvd drive.
then uc an boot with it.
Let em know
May 29, 2009 | Dell Latitude CS Notebook
MY computer is not booting when i connect my new DVD.
Please make sure that your HDD and DVD ROM drives are getting detected in BIOS. Are you using IDE or SATA drives?
May 19, 2009 | ASUS M2N-MX Motherboard
Problem loading an OS onto a Dell XPS One 2010
YOU NEED THE BIOS UPDATE FOR THAT ,,GET IT FROM A ANOTHER CPU ,,BOOTABLE DOWNLOAD,,PUT IT ON THE DELL ,,THEN XP,,CHECK THE DELL WEBSITE
May 15, 2009 | Computers & Internet
My computer wont boot properly
Try to check first if your hard drive is working. Just follow the steps.
  1. Load BIOS Utility by pressing any of the following keys upon booting or as soon as you have turn on your computer. (keys may varry depending on the brand or type of computer you are using but the following are the most common (del, f1,f2,f10) Just try any of the following.
  2. Under advanced option please check you hard drive settings. A numeric value should be displayed on the list or in some cases if you see AUTO in this option it means the BIOS automatically detects the hard drive. Just place your cursor on this option and press enter. The BIOS should react and will display the type of hard drive installed.
  3. If BIOS utility was unable to detect the hard drive and you still have a blue screen everytime you boot you will need to reinstall the operating system or run your recovery disk .
Jun 23, 2008 | Computers & Internet
LG GH22LS50 DVD-RAM Burner Logo
120 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
