Question about Dometic RM2652 Refrigerator
Dometic rm7732 not cooling
Have a unit that was not cooling on gas or AC yet if you ran it on gas while pluged in to AC it would work. replaced circuit board. now it seems like it should work, runs on AC getting power to 120v AC heaters, when on gas its getting a good flame. Yet i get no cooling at all with the new board. Is the cooling unit bad??
  • 1,879 Answers
You actually got it - check the colling unit part (connection from either AC or GAS / if it is still good or gone bad
Posted on Jun 17, 2008
    Master:
  • 638 Answers
Yes if its not cooling ur cooling unit is bad for sure.
  • 1 more comment
  • hemant somaiya
    hemant somaiya Jun 17, 2008
    hve u checked all the connection inside.try doing that too
  • hemant somaiya
    hemant somaiya Jun 18, 2008
    any more updates
  • hemant somaiya
    feel free 4 further assistance
    Genius:
  • 3,422 Answers
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Priya darshan Jun 17, 2008
    Is there heat in the back of the unit? If the burner is not making heat
    there is probably a problem with the electronics. Try the electric and
    gas settings. If the burner is producing heat there may be a problem
    with the cooling unit. Check for a yellowish powder residue or an
    amonia smell. That would indicate that the cooling unit that is leaking
    coolant. Dometic has a safety recall on some models for leaks near the
    burner.
Dometic RM2611, Freezes fine, Refrig OK on AC, but warms up when on LP gas. Can I safely increase the orifice size from #53 to #58? Thinking that will increase the flame and produce more heat.
Check the gas regulator and the lines for particles of dirt. You have modified the refrigerator it is going to take some work to find what is wrong. Don't modify the orifice from what it calls for.
APPLIANCE 911
Aug 27, 2016 | Dometic Refrigerators
Rm2352 will not work on AC, pilot will light, but then will go out. No cooling
LP check for cobwebs in lines and good gas pressure ac check heater element if ok disconnect thermistor from back board run overnite if ok replace thermistor if not bad cooling unit replace
Jan 29, 2014 | Dometic RM2652 Refrigerator
Dometic RM 3662 not working on gas or AC power. I've changed the heat element, I can see the flame of the burner. What's going on that the unit won't cool off. Tried gas for 5+ hours and the fridge seemed...
When running on Electric insure that the rear coils of the cooling unit are getting warm. If the refrigerator is level and the coils are warm and the refrigerator does not cool then you more then likely will require a replacement cooling unit. I have attached a small video that may help with the diagnoses. You can also give us a call toll free 1-888-782-6665 ArctiCold Refrigeration We keep it cold
Aug 27, 2013 | Dometic Refrigerators
Dometic RM7732
check gas pressure if ok clean flame sensor that's connected to ignitor
Apr 04, 2013 | Dometic Refrigerators
Dometic rm7732 replace cooling unit
order cooling unit it has directions inside
Mar 19, 2013 | Dometic Refrigerators
NDR 1292 - Was freezing/cooling on electric, but stopped freezingcooling, tried gas but doesn't freeze or cool
Since it does not work on either AC or gas - do you have DC to the unit? I have spent many hours troubleshooting a Dometic that turned out to be a corroded DC connection.
Jul 26, 2011 | Dometic NDR 1292 Refrigerator
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
Dometic RM2652 Refrigerator Logo
368 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
