Question about Exercise & Fitness
Hi,mr expert i have a problem with my tv monitor on the treadmill,that suddenly the monitor don't get power,i checked the wire connection,everything is okay.Do you think the problem comes from the monitor is going Bad? Thank you.
  • 42 Answers
Hi i have had a same problem, but when the monitor on my treadmill stopped i followed the wireing to the control panal and found that a fuse had blown. it tock me a long time but was worth it, now i have cut the main power wire connecting to the monitor and put in my own fuse kit with a higher volt. you can get these cheap from maplins. and if your cant find any fuses etc then i would take the monitor off and take it to any car audio shop and they will test if. hope i have helped
Posted on Nov 11, 2010
Dell ST2210 suddenly will not power on. Tried different power cord, outlet, unplugging everything but the power cord and still nothing.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 21, 2014 | Dell Computers & Internet
Pacemaster treadmill no power
http://www.youtube.com/watch?v=N6Yg5S0WML8
see the step for torubleshooting your problem.
Of course test the breaker or fuse from your house. See if the wire ground is connected to your outlet supply. Do not use any extension cord.Use regulator voltage recommended.
If necesary call some electrician .
sincerely.
Dec 22, 2011 | Exercise & Fitness
Shuts down after running a few minutes
hi when you mean shuts down it that the power or just the belt, if everything including the power turns off then check the trip switch on the front of your treadmill, and if you are using an extention wire on a roll, please unroll the whole thing that can cause a short. and if you can smell any burning thats a sign that the motor and belt are either too tight and on they way out.
Nov 12, 2010 | Cadence Weslo 620/630 Treadmill Walking...
I don't have a manual for my Weslo Cadence 2300 treadmill. The accusmart monitor doesn't work. Is it just a battery thing? How do I get in to change it?
The accusmart monitor lifts off the console by placing your fingers in the front. You should be able to then pull the unit off of the console. It is only held on by three snaps. The battery is accessed on the back of it.
Jan 21, 2010 | Weslo Exercise & Fitness
Wiring or power shortage in treadmill
I would check the connections between the console and the lower unit. There is a connection on the right side (facing the console). There should be 2 bolts holding the console on that side. Remove them and lightly pull the wire harness out there will be a red plug.
Nov 09, 2009 | Exercise & Fitness
Sharp LC46SB54U TV will not power on
It can be as simple as a blown fuse in the main power supply module, if you get not indicator light at all, then it will be the power supply has gone out, if you do get some indicator light, the 5v standby power supply is still functioning but not the main section of the power supply module. The filter capacitors look good, no bulging tops?
Sep 09, 2009 | Sharp LC46SB54U 46 in. LCD TV
No picture but only sound
If you are expert and have experience then follow the instruction given below:
Check first Filament is lighten-up ? If yes then check ABL Voltages, if filament voltages not present check horizontal out put transistor. and check also safty resistances in surrounding area of H OUT Transistor.
And if you are not a tech person then i advise you to please contact any expert nearby, this problem bit technical.
Hope this will solve the problem.
Thanks for using fixya.
Jul 24, 2009 | Sony KV-36XBR250 TV
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Suddenly router stopped working!
Hi jsamanta!
First of all check if the power light is blinking or solid. if it's blinking reset your router.
When your computer is directly connected to the router try checking the IP address by clicking start>run> type cmd then ok. then type ipconfig then hit enter. IP address should be something like 192.168.1.100. not 169.254.xx.xx. if it's the latter reset your router. use a ball point pen or a paper clip. the reset button is a small hole at the back. If the IP address is like the first one i've mentioned. log-in to your router.
launch browser (internet explorer or firefox)
type http://192.168.1.1 or whatever your default gateway is. go to the status tab and check if you are getting a WAN or internet IP address. if not you will see a "release" and "renew" button. hit release then renew. if you're still not getting anything. do a power cycle. turn everything off. connect everything the way they are supposed to be connected. turn on modem first then router then computer.
If everything fails the last options is a firmware update on the router.
Hope this helps. =)
Oct 11, 2008 | Linksys Wireless-G Broadband Router
Acer P221W 20in blacking out
check your graphics card wait 20 minutes or more see what comes up i recently had that or if u try everything eg replacing everything and it still don t work try rebooting the computer with the recovery disc which means it will wipe out everything programs everything.
Sep 28, 2008 | Acer Professional P211 21" CRT Monitor
Exercise & Fitness Logo
60 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
