Question about Panasonic Lumix DMC-FX50 Digital Camera
Panasonic Lumix DMC-FX50 when switched on the zoom goes to maximum on it's own and nothing works. Tried removing the battery, charging it and changing it for another.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 11, 2010
  • Bradgate5 Nov 11, 2010
    thanks, but regret none worked.
  • Andrea Lock
    Andrea Lock Nov 11, 2010
    Hello
    OK, as i stated, this is the extend to which you can go on trying to fix this specific error. I also mentioned, that if none of the above suggestions worked for you, you will unfortunately need to take your camera in to a repair store, where they will need to open the unit up and replace the lens, $100.
    I would please like you to reconsider the rating you gave on the specific solution.
    Feel free to let me know if you need any further assistance.
    Kind regards
    Andrea
Panasonic fx50 shutter
Reset the camera , clean the lens surrounding area, then try again and let me know.
Aug 06, 2012 | Panasonic Lumix DMC-FX50 Digital Camera
How do you charge panasonic lumix DMC-LS6
You don't. The DMC-LS6 uses standard AA batteries, either disposables or rechargeables. If you use rechargeable batteries then you must charge them outside the camera using a separate charger. AA rechargeables and chargers should be available at just about any department, electronics, or office-supply store.
Jul 29, 2012 | Panasonic LUMIX DMC-LS6 Digital Camera,...
Where do I load 2 batteries in the digipower rapid charger
Panasonic DMW-BCG10, DMW-BCG10E, DMW-BCG10PP Battery, Technical Specification: Battery Type: Li-ion, Voltage: 3.60V, Capacity: 895mAh. Dimension: 41.60 x 30.40 x 9.40 mm, Product Type: Replacement Battery (Brand New). Compatible with: Panasonic Lumix DMC-TZ10 Series, Panasonic Lumix DMC-TZ18 Series, Panasonic Lumix DMC-TZ20 Series, Panasonic Lumix DMC-ZR1 Series, Panasonic Lumix DMC-ZR3 Series, Panasonic Lumix DMC-ZS1 Series , Panasonic Lumix DMC-ZS10 Series, Panasonic Lumix DMC-ZS3 Series, Panasonic Lumix DMC-ZS8 Series, Panasonic Lumix DMC-ZX1 Series, Panasonic Lumix DMC-ZX3 Series. Panasonic Lumix DMC-TZ22, Panasonic Lumix DMC-TZ6, DMC-TZ8 and Panasonic Lumix DMC-ZS5, DMC-ZS7.
Panasonic DMW-BCG10 Battery
Jun 04, 2012 | Digipower Battery Charger
I have a Panasonic Lumix DMC-FX50 Digital Camera that all of a sudden says memory card not inserted when it actually is. I've tried formatting the card on my pc and still nothing. I cant use the camera...
Hello Optimus,
From the descriptions you said, it is unlikely that it is the card that is malfunctioning. It is probably the card slot inside your camera. Make sure that your card is inserted firmly. Also, check the inside of the card slot if it has bent / broken connectors. It might need servicing / replacing.
Oct 28, 2011 | Panasonic Lumix DMC-FX50 Digital Camera
Screen cracked, can I replace the screen?
If you send it in, you will be charged about $180-200 and what you will get back is a refurbished camera which may or may not be the same model. You can google "how to replace a screen on a Lumix DMC-FX50 and you may get lucky with instructions and places where you can order the screen. Probable total cost....about $50 and your time.
Oct 06, 2011 | Panasonic Lumix DMC-FX50 Digital Camera
No power
I also had this problem - and by accident I found that the battery just wasn't pressed down enough onto the contacts when the door was shut.  I now use a little bit of cardboard on top of the battery - then I close the door - now it works fine
Jun 26, 2008 | Panasonic Lumix DMC-FX50 Digital Camera
Camera problem
I have a Lumix DMC-TZ1 and my camera is having simular problems. The camera turns on but the buttons don't work. I can not zoom or take pictures. I can turn the auto stabilizing on and can change photo modes by turning the nob. But the menu button, nav buttons are not doing anything. The screen goes on and everything. I have tried removing the battery and nothing happens.
Apr 06, 2008 | Cameras
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix  DMC-FX50 Digital Camera Logo
78 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
