Question about Zyxel P-334WT (P334WT) Firewall
Ive lost the setup cd for my zyxel p-334wt - Zyxel P-334WT (P334WT) Firewall
  • Anonymous Mar 07, 2009
    i cannot do the whole
    ghost
    things because i have lost the cd and i do not have the program on my computer.
    i need to install it somehow using a driver or something because i need the internet and i do not have the cd so i cannot install the program.
    Genius:
  • 1,011 Answers
Sir,
U must prepare ghost for the software. Which there is a ghost software will be available on this link
www.brothersoft.com/downloads/ghost.html
This software is installed after that u have get a copy of software in your system. It means u can installed the software (zyxel p-334wt) to other systems. Simply means the software is backup by ghost software without the setup files. And to be installed in other systems also. ok
Thanks
good luck
Don't forget to rate the solution
Posted on Jun 29, 2008
I cannot access the router software to reset, can I do a manual reset? The router is a Sitecom WL322.
beside the power connector you can see a small hole, you just pin in to the hole and hold for 10 to 15 seconds to reset the router.
Mar 18, 2010 | Zyxel P-334WT Router (91003155003)
How do i pot forward a sitecom wl 322
visit www.portforward.com its free and will help u will all the details
Jan 07, 2010 | Zyxel P-334WT Router (91003155003)
Can I completely delete the memory from my Zyxel P-334WT router?
Hi there, in short yes. the reset button on the back will delete all the info on the router however a short press will not. What you will need to do is hold the button down for a good 20 second.... if this does not work then pull the power lead out and push it back in with the reset button pushed in, again for a good few second. Now to view all setting on the router before hand open your web browser up and in the top address bar type 192.168.1.1 or 192.168.0.1 the access code for your router varies on the make but can usually be found in the manual.when asked for a user-name and password just enter those (usually the user-name is ADMIN & the password is PASSWORD or also ADMIN. anyway you shold then be able to view the log and all settings.... hope this help ....Tony A
Dec 13, 2008 | Zyxel P-334WT Router (91003155003)
Problems with forwarding on the Zyxel P-334WT router!!!
You didn't say what game or what router. Can't get much help unless you give us something to work with.
BXH_5
Jun 17, 2008 | Zyxel P-334WT Router (91003155003)
P-334wt
Suggestion,
First, go to ur Router Configuration Page. There are 2 pg into related WireLess Configuration Settings. So u find ur problem into the WPA security configuration is under the wlan Security section, and then you select WPA PSK (Pre Shared Key) and TKIP encryption for Lan security. As well as changing the WPA Mode to enabled, u will need to enter a WPA Pre-Shared Key. So u found, which is a Network key and why to need.
mr-winthaw@myanmar.com.mm
Raider.CsStriker@gmail.com
Oct 22, 2007 | Zyxel P-334WT (P334WT) Firewall
Not working with Vista
May the router is not compatible with vista. Just try to use it with xp.
Aug 23, 2007 | Zyxel P-334WT (P334WT) Firewall
P-334WT Router Freezing
Your first step is to upgrade the firmware. OR re-install the firmware. Do you mean freezing like, lights lock up and stay on regardless of the activity? Which that would point to firmware. Or do you mean that your internet just cuts out? Which I would look more towards your computers browser, possible background applications or even the NIC.
Jun 14, 2007 | Zyxel P-334WT (P334WT) Firewall
Router Not Working
First of all Reset by pressing a reset button or with the help of a pen. turn if off and restart ur computer Once you connect ur computer with router.. go to start-run- type ipconfig. if you are getting an ip address in range of 192.168.1.2 to 192.168.1.255, 1.Launch your web browser(IE). Enter ?192.168.1.1? as the web site address. 2.The default password (?1234?) in internet access setup choose "Encapsulation as ethernet and there should be nothing in username or password.incase you have been provided with username and password from ur ISP then enter those with ip address assignment setting as dynamic. See if you can open the routers settings page. once you open it follow the instructions given on this link in .PDF format to SETUP ur router for ur internet connection. http://us.zyxel.com/web/download2/P-334WT/quick_start_guide/P-334WT_1.pdf To learn about ur router n setup more visit: http://us.zyxel.com/web/download2/P-334WT/support_note/P-334WT_3.60.pdf I am also using the same router and i did the same thing with the help of *** support team. i got it fixed in just 15 minutes. u can contact them on *** Just try it out and let me know or call *** team. i am sure they will help you out. Cheers!!
Dec 14, 2006 | Zyxel P-334WT (P334WT) Firewall
Zyxel P-334WT (P334WT) Firewall Logo
147 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
