Question about Lexmark X5470 All-In-One InkJet Printer
I need to connect my phone line to my printer to enable me to send faxes, how do I do this.
    Genius:
  • 1,087 Answers
Refer to the printer's User's Guide on how to connect your Lexmark X5470 to your telephone line for faxing. If the printer software is already installed on your computer, you can access the printer's User's Guide by going to the Start menu -> Programs -> Lexmark 5400 Series -> User's Guide (applicable to Windows OS). If not, you can download it from the Lexmark website for free using this link: Lexmark 5400 Series All-In-One User's Guide. Scroll to page 12 for the fax setup instructions. Also, check page 71for faxing instructions (sending, receiving, etc.). Hope this helps.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Posted on Nov 11, 2010
Lexmark platinum pro905 fax
If you're having problems sending faxes, make sure that the printer is connected to an active phone line. The best setup would be to connect the printer straight to a wall jack and the other end of the phone cable should be connected to the line port at the back of the printer.
If you're having receiving faxes, check the fax settings > Ringing and Answering. Check if the Auto Answer is enabled and check how many rings the fax will pick up any faxes sent to your number. If you have an answering machine connected to the same line, set the printer to pick up 3 rings higher than your fax machine. If you have a voicemail service, you'll need to get a distinctive ring feature from your phone provider.
Oct 29, 2012 | Lexmark Platinum Pro905 multifunction...
My company lexmark X642e all in one machine was faxing fine. I unplugged the fax line and plugged into another fax outlet plug and it would not work so I plugged back into the original fax line outlet and...
Make sure you plugged it back into the right port on the printer itself. The one I have actually has two different phone line plug-in ports - one is for the FAX line that connects to the wall. The other is so you can attach a separte phone as an extention to talk on. Good luck. Also, after it is plugged back into the wall, did you power down, wait 30 seconds and then power back on? Sometimes these things need to recognize at start up whether or not they are connected to other devices, etc. Good luck.
Jun 17, 2011 | Lexmark X642e All-In-One Laser Printer
Which port to use for fax???? sonyajohnsonrn@yahoo.com
Followup the steps to setup the printer to send/receive fax.
Connect the phone line ( wire ) to Line 1 Ext at the back of printer port.
The connection is from the Phone socket to printer.
Press the Auto-Answer button on the front panel of the printer to enable automatic fax receiving.
If your no. of rings on voice mail or Answering machine is 4, you need to set 6 Rings to Answer on printer to receive the fax or else the printer will start accepting all the voice mail calls.
Press the Setup button on printer front panel
Scroll till you find Basic Fax settings Or Advanced Fax settings - Press OK
Choose the option Rings to Answer - Press OK
Set the No. of rings. - Press OK
Your printer is ready to send/receive Fax.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 02, 2010 | HP Photosmart C7280 Laser Printer
I'm trying to receive a fax on the 7120 and i'm having a hard time figuring out which chords need to go where. can't find the manual.
Click on the link to download the Manual for your Printer - Click here - Printer Manual
Thank you for contacting FixYa
Dec 02, 2010 | HP OfficeJet 7120 All-In-One Printer
How can I send a fax through a home phone line? I was given this as a gift and I don't have manual. I was wondering if there was a way I could send a fax through my home phone line, since I don't have a...
A regular old (POTS) phone line will send/receive faxes just fine. If you want to connect it to your computer, you'll need TWO phone cords: one into the wall, and one into the computer, with both connecting into the fax machine itself. Those ports should be marked on the fax.
Feb 18, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Cannot send a fax
For a fax to work you do not need a broadband. What you need is a phone like. It seems that you are trying to use broadband for fax because it is the same phone line that they both are on. Sorry, will not work that way. If you trace back you will find that there is a little box that has the phone line coming into from outside. The box splits it into phone and dsl. It is this phone line that should go into the fax and not the dsl line.
So please remove the dsl line from the fax and connect the phone line and you will see that the fax works.
Dec 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
Do you need an extra phone line for a fax on your printer
it depends on what type of printer you have...i actually have an HP officejet j3500 series, it a fax, printer,scanner and copier in one.. when im using it for sending fax messages, i just dial the number where im sending it and it automatically faxes (phone keypad and handset is included)... and i use it as my printer too so its already connected to my pc..so easy to use...
but but but... i actually connected a separate phone line (our original phone from our provider) to the hp j3500 series cuz sometimes i need to speak first to thr person im sending fax before i send the message... i think that is for manual sending of fax...
so if you want to send manually (speaking first to the person before sending) a separate phone line is required (connected to ur fax)
but if u want autofax, then i dont think its necessary...
there u go...
visit this website to learn more.. hope this is useful
http://h10010.www1.hp.com/wwpc/sg/en/ho/WF05a/18972-18972-3328064-3328083-3328083-3440951.html
Sep 10, 2009 | Lexmark X2470 All-In-One InkJet Printer
Our HP Officejet 5600 won't receive faxes.
Here is the answer to your question.
Error code 244 can mean any of the following things: :
1. You or the person sending the fax pressed the STOP key , causing the session to stop before completion.
2. The fax machine on the other end determined that there is an incompatibility with your machine and the one you are sending to and stopped the fax session.
To fix this you can try the following things. Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Make sure the fax machine you are sending to can accept and use polling.
  • Select a slower "receive" speed.
  • Enable or disable the ECM setting.
Error Code: 232
1. Can mean that a communication failure has happened between the two machines.
2. It may also mean that the user of the FAX machine you are sending to has pressed the STOP key
3. If call waiting is enabled, it may cause this error. Disable call waiting on your phone line, if you have a fax machine connected to it. The click or beep on the line that indicates you have a incoming call, can STOP a fax session.
4. Another cause of this error code is that the power was interrupted to the machine you are attempting to send a fax to.
Things you can do to solve this problem: Try them one at a time, and if they don't work, place them back the way they where before you changed it.
  • Try disableing ECM. However, this may reduce the quality of your faxes.
  • Ask the person you are sending the fax to to set the machine to receive at a slower speed.
  • Try the fax again at a different time, incase it is a problem with the phone line.
  • If you phone lines are old, or there is static on the line it may cause trouble sending a fax.If this is the case you will need to contact your local phone company or whoever is responsible for servicing your phone lines.
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a new all in one with fax, I am not sure how to send a fax
You do not need a dedicated line. You just have to have a working phone line connected.
Jan 29, 2009 | Lexmark X1270 All-In-One InkJet Printer
MFC-8500 fax operation
If there is noise on phone line machine reduces speed to enable fax to be sent. Have line check or try machine on different phone line to ensure it is a phone line problem.
Dec 03, 2007 | Brother MFC-8500 All-In-One Laser Printer
Lexmark X5470 All-In-One InkJet Printer Logo
140 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
