SOURCE: My Washing machine stains clothes;
Its the felt drum seal (clothes getting stuck in there and getting the greasy adhesive on them). I took a Q-tip and slid it between the felt seal and the metal, and the color and consistency of what came out was the same as the marks on the clothes.
Call a Whirlpool tech, they can replace
SOURCE: i have TOSHIBA AW 8500
Toshiba does not seem to support washers in USA. You should go to Toshiba worldwide support at http://www.toshiba.co.jp/worldwide/index.html. Select your country and follow the steps to get a phone number. Talk to a CSR and they should be able to give you a part number and/or dealer near you.
It sounds like you need the Lint trap for your Toshiba AW 8500S washer. Good luck!
SOURCE: Please help us our washing
Please help us our washing machine is Toshiba AW8800S and theirs a error E7 what is that error means? please send to my email [email protected]
SOURCE: I have a Toshiba Washing
aoa may machen is toshiba problem is timer not work and led blinking you gev meen anser waht porblem hai thanks
SOURCE: My washing machine modle toshiba
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
