Question about Foxconn 45CMX socket LGA775 motherboard (16897)
Can i use 5.1 audio with foxconn 45cmx onboad audio. i'm using windows 7. they only display stereo on audio channel settings on sound configuration at control pannel.
    Guru:
  • 1,705 Answers
You should be able to, you may need to download and install Win7 compatible audio drivers for your motherboard. You should be able to find those at the Foxconn website. Follow links for support and downloads.
Posted on Nov 11, 2010
45CMX/45GMX/45CMX-K I do not know what video cards and processors are compatible with this motherboard as I want to upgrade my pc
Hello download the manual here:
http://www.foxconnchannel.com/ProductDetail.aspx?T=motherboard&U=en-us0000341
Intel Core 2 Duo, Pentium Dual-Core, Pentium D, Pentium 4, Celeron D, Celeron processors, Socket T (LGA775)
- 1333(oc*)/1066/800/533 MHz (FSB)
- Dual Channel DDR2 667/533/400 x 2 DIMMs, Max. 4GB
- 1 x PCIe x16, 1 x PCIe x1, 2 x PCI
- ATA x 1, SATA II x 4
- 5.1 channel Audio
- 10/100M LAN
- 8 USB 2.0 ports
Good luck
Jun 17, 2012 | Foxconn 45CMX socket LGA775 motherboard...
I have a foxconn 45cmx motherboard with a realtek alc662 sound card. I have alle drivers installed en updated but i have no sound. Can anyone tell me what to do?
Verify that the volume is not set to mute. If possible verify that the Front Audio is disable when it is not connected to the front audio panel. To disable Front audio as below: pin 5,6 and pin 9,10 should be short with jumper.
Nov 02, 2011 | Foxconn 45CMX socket LGA775 motherboard...
I have upgraded to Windows 7 and also a new Gigabyte GA-H61M-D2-B3 Motherboard. 4GB DDR Ram I have plugged my Cambridge Soundworks SW320 in but I only get some sound, eg all music and back ground sound is...
Gigabyte GA-H61M-D2-B3 Motherboard supports 2/4/5.1/7.1-channel HD audio, whereas Cambridge Soundworks SW320 is 2.1 (only). Hence, the PC should be configured to provide 2.1 Channel output. The audio of your system may be configured to 2.1. So, please check the Realtec Audio sound manager/ configuration from the control panel or from tray (near clock) and set it to 2.1 (2 Channel Stereo Output).
Moreover, audio on your PC may be running on default HD Audio Drivers. So, you may also download/ install the latest drivers for Gigabyte GA-H61M-D2-B3 Motherboard.
(Refer to download section at the bottom of the page). After installing audio drivers, you would be able to configure the audio.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Creative Labs SoundWorks SW320 Computer...
I am having xp Home,board model foxconn 45cmx i cant install audio driver help me
Befor installing Audio install Below update package for audio.
then install Audio Driver
http://download.cnet.com/kb888111-exe/3000-2110_4-104699.html
i think it solves u r problem
RATE ME!
Jun 27, 2009 | Foxconn 45CMX socket LGA775 motherboard...
Find sound driver for foxconn 45cmx
doun load from net and install or use dark edition oprating system on full version option 5
May 31, 2009 | Foxconn 45CMX socket LGA775 motherboard...
FRONT PANEL AUDIO HEADER PINOUTS CONFIGURATION HELP
It really is your choice. You can use the AC'97 or HD but not both. Follow the wiring for the choice you select. Personally I'd go with the AC'97 setup as alot of games have issue with the Realtek driver. Hope this helps.
May 02, 2009 | Foxconn 45CMX socket LGA775 motherboard...
I have the same problem, solved it partly by downloading from the Realtek site, some drivers. Now the sound is OK but still the ethernet lan controller doesn't work, neither the pci modem.
Thanks and good luck!
pema rinchen.
Oct 21, 2008 | Foxconn 45CMX socket LGA775 motherboard...
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
210 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
