Question about Fellowes Cordless Optical Keyboard/Mouse 99666
How do I re-sync my cordless mouse and keyboard?
I cannot get the keyboard to sync. I can get the mouse to connect but not the keyboard. I put all new batteries in everything so thats not the problem.... I recently had to do a full restore on the...
I have a problem in getting my keyborad to function, I am not sure if I am using the right Logitech cordless mouse. If it's not the right mouse with USB connection how can I resolve this proble?
The Cordless Keyboard is MX3200
May 06, 2011 | Logitech Cordless Desktop MX3200 Laser...
I need to replace the batteries to a cordless logitech mouse, where are the buttons located on the wireless keyboard to sync everything back up? And how long do I hold buttons for?
I used to use a set of these
the button on the key board should just be on the bottom, if you dont see it it might actually be in the battery compartment. but im pretty sure its just on the bottom it might even be red.
to sync it, have the receiver plugged into the computer and the computer on. push the button on the receiver until the little green light flashes on the receiver then press the button on the keyboard, the light should stop flashing and the keyboard should by synced, do the same with the mouse.
Mar 26, 2011 | Logitech Cordless Mouse
Will not syc with receiver but mouse does have inserted new batteries
Hi! In order to pair your devices you need to push the sync button on the receiver and then push the sync button on the keyboard and mouse.
Mar 01, 2011 | Logitech Cordless Desktop MX3200 Laser...
Used my wireless mouse yesterday morning and then couldn't work in the evening.
I think that you should change the battery of the mouse or could be that the sync is not there anymore. Try syncing the mouse again by pressing the sync button at the bottom of it for 10-15 seconds.
Admin
HNetworking.com
Feb 03, 2011 | Logitech Cordless Mouse
Logitech mouse is'nt working
You might try re-syncing the mouse with the wireless sender. Push the button on the sender (plugged into usb port usually) and then push the button on the bottom of the mouse.
Aug 02, 2010 | Logitech Cordless Mouse
Mouse won't sync with the 'master'. Put in new batteries - no success. Keyboard synced up easily
wireless mouse / keyboards work on different channels, to avoid interference with other wireless units. There is a procedure for mouse to relearn the operating channel, usually hitting a hidden button on the receiving unit, and then hitting a similar button on the underside of the mouse. When successful, a light will blink on the receiver.
Dec 04, 2009 | Logitech Cordless Mouse
Cordless Mouse & Keyboard install I need help
if you have a disc for the new items ,install first,shut down pc, then take the old mouse & keyboard off connect the new wireless ones before rebooting
you may need to sync the mouse & keyboard by holding in the small little button on each item and the reciever unit untill the lights come on indicating it is recieving the signals from both mouse & keyboard.if this does not work put the old mouse back in reboot then go into control panel / mouse, and sellect wireless mouse ,turn off the pc plug the new mouse back in then boot up
good luck
Terry
Mar 09, 2008 | Computers & Internet
Wireless mouse won't work on hp multimedia cordless keyboard and mouse
Try changing the batteries in the mouse and then press the little sync button of both the mouse and the wireless receiver.
Nov 09, 2007 | HP Multimedia Cordless Keyboard/Mouse...
Fellowes Cordless Optical Keyboard/Mouse 99666 Logo
350 people viewed this question
Top Fellowes Computers & Internet Experts
gp63260
Level 1 Expert
Raj Trivedi
Raj Trivedi
Are you a Fellowes Computer and Internet Expert? Answer questions, earn points and help others
