Question about Iomega 500GB eGo BlackBelt Portable 34621 500 GB Parallel Hard Drive
To install do I have to connect both usb terminals to the pc?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
True. It requires more power, and hence to USB terminals.
pls. vote for better sharing
Posted on Nov 11, 2010
My computer has USB Terminal, and my Canon Mini Digital Camcorder ZR60 has DV Terminal. How to connect ?
you have to buy and install IEEE1394 Firewire adapter to connect DV devices to your computer. Probably a cable too.
Oct 09, 2014 | Video Cameras
I cant load my pictures in my computer
If images cannot be imported automatically into the Windows PC, check [Precautions] below.
[Precautions]
- Temporarily terminate resident software such as antivirus software.
- Connect the AC adapter or load a fully charged battery into the digital camera.
- If RealPlayer 10 is installed, select "Tools" - "Preferences" and then disable "Automatic Services."
XXXen the digital camera is connected to the PC, if the FinePixViewer starts up and images in the digital camera are displayed, skip Steps 1 to 5 and start with Step 6.
1. Start up the PC and then connect the digital camera and PC using a USB cable.
2. The "USB MODE" setting of the digital camera may be set to "PC CAM."
Set "USB MODE" to "Card Reader" or "DSC."
*Only in the case of the digital cameras that have the "USB MODE" setting in the SETUP menu
3. Check whether or not any mark indicating the USB connection (USB, CARD READER, USB symbol with an arrow mark, etc.) is displayed on the LCD monitor of the digital camera.
If not, the digital camera and the PC are not connected properly. Check the following points.
a. Restart the PC, disconnect and connect the USB cable and then try again.
b. If the PC has multiple USB ports, connect the USB cable to another port and then try again.
If no mark indicating the USB connection is displayed even after performing above Steps (a) and (b), the digital camera or USB cable may have a problem.
4. Check whether or not "Removable Disk" is displayed in "My Computer." (For example, when the operating system is Windows XP, a FinePix icon in the shape of a digital camera is displayed.)
If "Removable Disk" is not displayed, install the USB driver again.
5. Automatic startup software (Exif Launcher) may not function properly.
Perform the following procedure.
[Windows XP]
a. Select "Start" - "My Computer."
b. Right-click the "FinePix" icon and then click "Properties."
c. Click the AutoPlay tab.
d. Click "Music files" and then select "Pictures" from the displayed list.
e. Select "Select an action to perform."
f. Select "Viewing images with FinePixViewer."
g. Click the "OK" button.
6. The Automatic Save Settings may be incorrect.
Specify the Automatic Save Settings again by following the procedure below.
a. Start up the FinePixViewer.
b. Select "Automatic Save Settings" in the "Settings" menu.
*If "*** not found" is displayed, click the "OK" button.
c. In the "Way of Saving" column, click the "Browse" button to specify the storage location.
Feb 26, 2014 | Fuji FinePix A345 Digital Camera
On connecting with computer with usb it say to mulfuntioned
well just check your usb cable for any kind of damages and if not then just simply clean ur usb port with a brush as dust particles accumulated on the terminals prevent continuos connection and causes usb malfunctioning .....
Feb 10, 2011 | Computers & Internet
Don't know where i plug in my printer
I think you are new with the PC or Printers, if not, I am sorry to underestimate you, not actually, Well, I was just trying make you concentrate, This printer is to be connected to the PC via USB port using USB cable, here's the pic representation : usb-printer.gif The Flat terminal is to be connected to the PC and the Smaller terminal is to be connected to the Printer. Don't worry, It fits with the corresponding ports. printer-usb-port.jpg USB port on the printer looks similar with the above shown image. 67411-usb.jpg You have to connect in a similar way as shown above to the PC.. Good luck...
May 10, 2010 | E-Machines eMachines Desktop PC
My usb pendrive is not format it say taht there is no disk please insert any disk plese help me
1.Reinstall ur usb3.0 and try to connect ur usb drive again.
2.Else try with others usb port in ur motherboard.
Mar 29, 2010 | Kingston flash memory card - 256 MB -...
How do i transfer pictures to my memory card
Connecting the camera to a PC
1. Turn the PC power on.
2. Turn the camera power on.
3. In any mode other than Voice Recording mode, press
the MENU button.
4. Press the LEFT/ RIGHT button and select the [SETUP]
menu tab.
5. Select the [USB] menu by pressing the UP/ DOWN
button and press the RIGHT button.
6. Use the UP and DOWN buttons to select
[COMPUTER], and then press the OK button.
7. Press the menu button twice and the menu will disappear.
8. Connect the PC and the camera via the USB cable.
- Insert the small plug of the USB cable into the camera USB connection terminal.
- Insert the large connector of the USB cable into the USB port of the PC.
- The plugs must be firmly inserted.
note: driver for a40 must be installed in your computer.
you can get it here.
Jan 09, 2009 | Samsung Digimax A40 Digital Camera
Zyxel P660HW with vista issues
If you are connecting via usb you will need to install all software and drivers on your pc before plugging modem in. If you did install them already you may need to reinstall
If you connect through ethernet (RJ45 terminated network cable), you may have a firewall preventing regular acess to network.
solutions
1) restart pc and modem it may work just with this
2)USB only: reinstall all modem software, then restart all.
3)Ethernet only (network cable), |Restart all and disable firewall. If this does not work you may need to change network settings on your computer (fo example change IP from static to dynamic).
regards
Feb 24, 2008 | Zyxel P660HW-D1 Router
System file is corrupted
Look here Below, for your "Fix". But ya gonna hve to find a way of getting the info into your PC.. Does it have USB? You could remove the Hard DRive and connect say Via USB/IDE/SATA adapter on another PC install necessary files into the drive, and or fix it there, and or return to the "Bad Machine" and perform the Fix as per below link. Good luck. http://support.microsoft.com/kb/307545
Jun 06, 2007 | WYSE WT9235LE (90203805) Network Terminal
Problem in connection to a PC
in spanish.... use translator please ya revisaste el cable usb? el usb es front o rear, probaste usarlo en otro diferente o en otro equipo?.... si funciona... pude ser problemas de configuracion del sistema operativo y habria que reinstalarlo, si es cambiando el usb, generalmente los front son 1.1 y los rear 2.0, si aun presenta problemas usa un driver lo mas actual posible, no el que viene con el hardware... y si no uffff soporte tecnico del fabricante.NVV
Dec 11, 2006 | Fujitsu TeamPad 500 (pbt500-13) Portable...
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Iomega 500GB eGo BlackBelt Portable  34621 500 GB Parallel Hard Drive Logo
157 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
