Question about Ricoh Aficio 2022 All-In-One Laser Printer
HI I AM GETTING ERROR SC 542 PLEASE HELP ME OUT THANKX
  • 2 more comments
  • majidhc Nov 20, 2010
    hi i am getting sc542 in my aficio 1022 ,I have applied service panel #5810 but it happened again what should i have to do thanks
  • majidhc Nov 21, 2010
    i have done this what you have told, it took 25 sec to start functioning but at last it reveal same problem sc 542, please tell me your next process . thanks
  • majidhc Nov 22, 2010
    WHAT ABOUT THERMISTOR IT HAS TO BE CHANGE FIRST OR DIRECTLY THERMOSTAT ,AND FROM WHERE IT CAN BE FOUND THANKS
  • Ricoh Master
  • 4,737 Answers
There are several fixes for this error code, but honestly I am not very familiar with this Model.
Actually, the code indicates that there's problem with the Fuser Unit, means it heating temperature is Lower than what it should be. If it's actually a hardware issue, you need to replace few parts, i.e. the thermostat, but if it's a fake or temporary issue, try this method.
  • Press the yellow "C" button
  • Enter 107
  • Press the red "C" button and keep it hold till the display changes
  • Press Printer SP button on display
  • Turn the power off with the big red switch on the front side
  • Turn power on again.
The error code should no longer display on the screen. If this doesn't fix, let me know. I'll post back some more methods. Good luck.
Thanks for using FixYa.
Posted on Nov 20, 2010
  • Lebanon Raingam
    Lebanon Raingam Nov 21, 2010
    Well, it means there's actual problem with the fuser unit. Now, you have only two options left. First, you can try replacing the Thermostat on the Fuser. It's easily identified, should be secured with two screws and it should look like this:
    (Ricoh Thermostats)
    If you've ever replaced the heat roller of the Fuser, then you might have removed it since it's to be removed before you disassemble the Fuser unit to remove the Heat Roller.
    Even if replacing the thermostat doesn't seem to be of help and the error still shows, I would highly recommend you to replace the Fuser Unit or try with another working Fuser. If you have spare/s that'd be great to get this confirmed that fuser itself is the cause.
    Good luck.
  • Lebanon Raingam
    Lebanon Raingam Nov 23, 2010
    Replace the Thermostat, if that doesn't help, you'll also need to replace the thermistor.
    You can find it 1. Here
    Good Luck.
  • 3,530 Answers
Welcome to Fixya
This could be a fuser unit problem and need repalcement. Try to reset the unit first by following this procedure. If same thing will happene then you need to replace the fuser unit.
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Thank you for using Fixya!
Posted on Nov 19, 2010
Error sc 542
this is a fusing error
change the set of thermisters in the fusing unit
Jan 20, 2014 | Ricoh Aficio CL3500N Laser Printer
:Ricoh Aficio SP 3510SF error SC 542
Yes your MFP has had a fuser reload error. It's not permanent though. Sometimes the thermistors don't read the right temperature due to the thermistor getting excess toner built up on it or it gets moved away from the hot roller. This SC error usually can be reset by powering down the printer. It must be powered down correctly or you can corrupt the hard drive.
Hold the power button down on the operation panel until the screen goes dark. Then, physically turn the power switch off on the side of the unit. Once the unit has completely powered down and all lights are off, toggle the power switch back on. The unit should power back up normally. If the SC 542 returns, you'll have to have a technician check the fuser out.
Oct 24, 2013 | Ricoh Aficio SP 3510SF Laser Multifunction...
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
Hi, i have a error code SC 542 but i don't see Yellow Key [clear modes] button on control panel please send me deatil moeen_rauf@yahoo.com
SC 542 Heat roller warm-up error and for that you will need a technician since the machine may need some part replacement .
Feb 15, 2011 | Ricoh Aficio CL7200 Laser Printer
Sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
May 22, 2009 | Ricoh Aficio CL7200 Laser Printer
Im having an error sayig SC:542 so how can i solve this kid of problem?
This is a 'fuser" warm up error. You could have a blown out heater lamp, or fuse, but most often this is caused by a power fluctuation. The reset for this is done by simply entering the service mode, and turning the machine of/on with the main power (red button).
enter service mode as follows:
"Clear Modes"
" 1, 0, 7 "
then hold "Clear/Stop" for 2-3 seconds.
The display will change with "service mode" in the top corner.
Now turn power off/ on (red switch)
** Never go further into the service mode, as you can cause all kinds of difficulty.
If the code comes back, then you will have to get a technician on site to troubleshoot the fuser.
Please rate me :)
Apr 24, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Ricoh aficio 2027
SC542 is a warm up error from the fuser.
SC 870 is an address book error.
Turn the power off on the copier. Wait 30 seconds and then turn the power back on. See if it goes away.
Let me know if it doesn't.
Jul 12, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Sc 542 error code
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
Aug 13, 2007 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2022 All-In-One Laser Printer Logo
75 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
