Question about Philips SNN6500 Wireless Notebook Adapter
Why does my notebook keep overheating? - Philips SNN6500 Wireless Notebook Adapter
    Problem Solver:
  • 13 Answers
Many times overheating will happen if the cooling fan has gotten a build up of dust. Try to vacuum out as much as possible from all the vents. Use canned air or other compressed air (If you have access to an air compressor or a reversible vacuum that has a filter, you can use that), to remove dust build up. Also try to make sure that you set it on a solid surface, or a ventilated but still sturdy surface, and provide a little ventilation space on each side, so that it has a chance of getting cool air to it. Not a soft surface like a bed or your lap.
Posted on Nov 11, 2010
My Acer laptop keeps restarting randomly whenever i use it.
Most likely cause would be overheating due to clogged fan intake/exhaust or failing fan. If you want to tackle yourself Google "disassemble Acer ______ laptop" (insers your model number). You can determine if overheating is likely by carefully blowing some canned air into the fan intake.
Mar 13, 2016 | Acer Aspire 3935-6504 Notebook
Fujitsu LifeBook AH530 NoteBook turns itself off
Clean the fan and airways. It is probably overheating.
Nov 11, 2013 | Fujitsu LifeBook AH530 NoteBook
Overheating and thermal shutdown of computer
Make sure that you keep your notebook on a hard surface. Dont keep your notebook on the bed or on your lap. Doing so will block the hot air from escaping and the heat keeps increasing. Make sure that the hot air passes away freely. Buy an external fan which will help the notebook by suppressing the temperature.
Dec 28, 2010 | Acer Aspire One PC Notebook
Laptop shuts down due to overheating, M50SV
IMOP this laptop appears to have known issues re overheating. Make sure that your cpu fan is clean and all vents are clean. clean top of cpu of all dust and cpu grease residue and reapply a small amount of cpu thermal compound.
Realize that overheating will be an issue and compensate however you can. Most cooling pads are useless, so good luck there. You can throttle down the cpu, a terrible thing to do for a laptop that cost good money.
A SSD drive replacing your hard drive will lower over all temperature of your laptop, guaranteed. Expensive, but has other benefits.
Good luck.
Mar 13, 2010 | ASUS M50Sv-A1 Notebook
My asus notebook m6b00 keeps overheating and tunring off why?
Laptop overheating has become a more common problem in recent years as both the CPU chips and the video chips in laptop computers have become more densely packed with transistors, all of which generate heat. With both CPUs and graphic systems generating more heat, laptops can overheat if they are not properly designed or if ventilation and cooling is interfered with. The problem is compounded when manufacturers put desktop components in mobile systems, or when laptop design does not properly provide for laptop cooling under foreseeable normal use of the systems.
Laptop overheating most commonly signals itself by sudden, otherwise unexplained shutdown of an operating computer. If your laptop computer suddenly shuts down for no known reason, there is a high likelihood that the fail safe software in the computer is shutting it down when the computer temperature gets too high. Other signs of overheating notebook computers include constant or excessive fan operation, unexplained memory or operation errors, and inexplicable “blue screens of death.”
The problem often arises when you are using your computer intensively in ways that keep the CPU operating at high capacity and the hard drive and video systems busy as well. Gaming often leads to laptop overheating. Virus scans, compiling software and similar intensive tasks can also bring on the problem. The problem also, not surprisingly, sometimes occurs when the temperatures are high in the setting where the laptop is being used.
The consequences of overheating laptops can be quite serious. Your computer can be damaged, and may end up requiring expensive replacement of major system components, such as motherboards or graphic cards. In addition, medical researchers have reported health issues ranging from sterility to burned genitalia related to use of overheated laptops by fully clothed users.
If you have an overheating laptop and your computer is still under warranty, you should promptly report the problem to the manufacturer and seek their help. Because many manufacturers seem to engage in denial rather than cures with regard to this particular problem, you should also read the information on laptop overheating on this and related sites so you can better understand the causes, the consequences and the possible cures for notebook computer overheating.
Here is the to see some tips on why your laptop is overheating.
www.yboyandrei.com/notips
Aug 08, 2009 | ASUS m6n Notebook
My notebook is overheating
you need to buy a notebook cooling pad, if you don't have one on your laptop. this can help to reduce overheating of the laptop..
click HERE to see.
Jun 26, 2008 | Compaq Presario M2000 Notebook
Keeps turing off
It's look like overheating. Try to clean the fan and thermal module.
For 5630, Open the thermal door on the back of your laptop and you can see the fan.
Feb 08, 2008 | Acer Aspire 5630 Notebook
Computers & Internet Logo
52 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
