Question about Nokia 9300i Cellular Phone
Vibtate not working - Nokia 9300i Cellular Phone
  • 213 Answers
FIRST RESTORE UR CELL
CODE
*#7780#
SECURITY CODE IS
12345
IDRISH 911
Posted on Nov 11, 2010
Why my car engine vibtates
Many problems can cause a vibration in the engine. A fouled spark plug, a bad/clogged fuel injector, or if the timing is off, could all cause a rough vibration. If the car has gone over 40,000 miles since the last tune-up, you might want to try that first.
May 04, 2016 | 2005 Mazda 6
Why is it vibtating?
It probably has to do with the table surface you are using for your sewing machine. If the table is not sturdy, the machine (and table) will vibrate as you increase stitching speed. Try setting on something with firm, stable legs, ie kitchen table, dining room table and see if it makes a difference.
If it continues to vibrate, then something may be out of balance with your machine, in which case, you should probably take it in for a checkup.
Jul 19, 2015 | Sewing Machines
Vibtation starts at 52mph and increases with speed. just had tires rotated and balanced, possible causes?
If your tire are not seperated (Belt broke inside the tire) It's most likely that there's a problem with your driveshaft.
Mar 19, 2013 | Cars & Trucks
I feel vibration on my bike even when in low speeds
Possible that the foundation of the engine is loose, the fittings are not tight, the suspension is having issues or the engine timing tuning is not perfect.
All these factors can contribute to the vibtation but the most possible fact can be due to LOW RPM of the engine. So set the IDLE RPM higher by tuning the engine so that the engine vibrates less at low RPM.
Dec 05, 2011 | Motorcycles
2001 Buick park avenue shakes going down the
Have the alignment checked on the front end.
May 15, 2010 | 2001 Buick Park Avenue
Car has a grinding sound and a slight vibtation
Not likely the caliper , could be wheel bearing , bent axle , bent rim , steering or suspension part way worn out.
Apr 18, 2010 | 1995 Pontiac Bonneville
I have a 2007 HD Ultra Classic. I installed Hogtunes speakers and amp about 1 year ago. Last week I was riding N on 395 when speakers went out. Checked fuses,ACC fuse was blown. replaced, still no sound....
07 units are notorious for vibtation damage. 08 and later have an anti vibration modification. You need to check your fairing brackets and make sure they are secure. Either way, the radio is repairable. Iron Cross Audio can do it and also install the anti-vibration modification. (www.ironcrossaudio.com)
Sep 24, 2009 | Harley Davidson 426290 AM/FM Radio
TV makes a continuous distorted vibrating kind of noise...
for sure your tv dont have any ********?he he he....check where vibtation noise from but if it comes form inside the best solution is to bring your tv to a LG repair technician .
Sep 08, 2009 | LG RU-42PX10 42 in. HD-Ready Plasma...
Older Sears craftsman 15 hp 6 speed. Let clutch out and
Hello:
From your Description it Sounds like a Bad/Weak Clutch/Brake Tension Spring.
I have Just Joined this Site as an Expert and can Assist you Better if you Send me the Model Numbers Off the Unit.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger
May 11, 2009 | Garden
Nokia 9300i Cellular Phone Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
