Question about Asrock P4I45GV R5 Motherboard
Hii,my moniter does not work properly .....it may not caching signal or somthing other ,i don't know i have asus mother board,500 hdd,2 ram,win xp os what can i do ....
    Genius:
  • 1,672 Answers
Download drivers for that mobo to get an OPTiMUM efficiency, get it in asrock.com
Posted on Nov 11, 2010
Asus Xonar DG PCI 5.1 Playback is choppy with a "Matrix" like sound light "popping" sound occasionally using Windows Media Player 11 CD/DVD and Online My 8 year old's...
you need to download the audio drivers for you mother board, upon downloading make sure you type the correct model of the mother board to make sure it is compatible. that's all thank you.
Sep 09, 2011 | Computers & Internet
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
I want driver for the above. my os is win xp prof.with sp2
hii,
Each mother board has specific model no. and type,depending upon which we get to know which driver will work with the mother board.I suggest you to find out your motherboard type,like it may be,Intel 945 series or chipset.....so find out in detail.
Aug 10, 2010 | Computers & Internet
Hi, my system not working properly.
I don't think this is a BIOS problem. Sound more like you need to re-load windows and start from scratch. Make sure your USB is turned on in the BIOS.
Dec 25, 2009 | ASUS M2N-MX Motherboard
PCI IDE slot does not detect hard drive
Check if power cable to the HDD is connected properly or not.If it is connected then check the jumper settings on HDD.
Thanks
Mar 12, 2009 | ASUS P5GD1-VM Motherboard
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
ASUS P5GPL and 4 modules DDR-400 512 Mb Hynix - not work correctly
I CAN NOT LOAD WINDOWS XP IS THERE BIOS PROBLEM ?
MY MOTHER BOAD IS 815E ( P 3 )
WIN 98 EASILY WORKING BUT NOT WIN XP
Nov 04, 2008 | ASUS P5GPL Motherboard
No signal to monitor when booting.
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Apr 19, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
No signal on moniter
are you using an add-on video card? If so, then go to BIOS and enable it.
Jan 14, 2008 | ASUS VIA KT133 Chipset A7V133 Motherboard
Booting problem
try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Dec 22, 2007 | Biostar P4M890-M7 Motherboard
Asrock P4I45GV R5 Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
