Question about Canon P1-DHV Calculator
Loading paper I cannot figure out how to load paper in my calculator. It has been a long time since I used it. loading paper tape is impossible! I get it in the back slot of the frame, but can't get it to load into the mechanics of the printer and progress when we press the feed button.
  • Anonymous Oct 14, 2008
    I have a Canon P1-DHV Palm Size Printing Calculator and do not know how to load the paper.
  • Anonymous Dec 04, 2008
    I need Help loading the paper someone help ASAP
  • 3 Answers
The entry point is on the back bottom of the machine. Cut your paper into a shallow triangle w/a slight point in the middle. Guide it through the slot on the back, and then lift that point up so that it goes into an almost invisible opening with small silver metal tabs on either side. The paper will want to feed underneath the entire black plastic mechanism, but don't let it. As the instructions indicate, the paper does not actually feed "under the black plastic plate", but through it. After you manage to insert the point of your paper through the correct slot, make sure the entire edge of the paper actually enters so it is grabbed when you push "Feed."
Posted on Feb 07, 2009
Need to load paper into calculator
There is a small flat area on the back of the calculator. Put the paper in this hole and press the FEED button.
May 06, 2010 | Canon P170-DH Calculator
Loading paper tape
open the calculator, put the paper in, then put the end of the paper into the slot, close it and that should be it..
Apr 10, 2008 | Casio HR-8TMPlus Calculator
How do you load paper into a canon p23-dh v
For loading paper into canon p23-dh v is to cut a piece of index card to the length of 3 inches and to the width of the paper you want to load. Tape evenly to the end of the paper roll and put into the ****, pushing gently in and at the same time pressing the 'Feed" button. It will immediately feed since it is firmer than the Poat-it paper.
Apr 26, 2010 | Canon P23-DH Calculator
I can not figure out how to load the tape.
It looks a lot like my Canon. I cut a nice straight edge on the paper feed it in where the paper normally goes and hit "Feed". Your key for feed may be an arrow or something different. Hope it helps.
Sep 18, 2009 | Casio HR-100TMPlus Calculator
Reloading tape roll on a Casio DR-T120
place the paper sticking out of the top, then close the cover. it will start working; good luck
Jun 02, 2009 | Casio DR-T120 Calculator
Load paper into cannon p23-dh v
While looking at the front of the P23-DH V printing calculator. Fold down the paper holder and turn the calculator back around to face you. Then cut the paper on the roll straight across. Then feed the paper into the slot in the back of the calculator. Turn the calculator on to the print mode. Then hit the "feed" button. The paper will feed thru and you are ready to go.
Dec 30, 2008 | Office Equipment & Supplies
Loading paper
Follow the illustrated instructions on the first page of this manual.
Jul 18, 2008 | Sharp EL-1197PIII Calculator
Loading paper
Its probably worn out. I have been messing with mine and if it does feed it is slipping and overwrites.
May 05, 2008 | Casio HR-100TEPlus Calculator
Trouble Feeding Tape into Calculator
use a thin plastic card and put it on the load,maybe you have a paper on printer ,press feed and you vill clear all paper path
Feb 01, 2008 | Canon P170-DH Calculator
Canon P1-DHV Calculator Logo
602 people viewed this question
old marine
old marine
