Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
My usb doesnt have a drive when i look to its properties. i cant open it either... it doesnt show on my computer. what should i do?
    President:
  • 1,812 Answers
Your pc & kingston flash driver already affected by virus ,you cannot maintain the folder options because autorun.exe is runnning, you should go to another pc ,where that pc switch off the autorun from >run>gpedit.msc> administrative templates>system>d click on turn off autoplay>ennable >d arrow>select >select all drivers>ok .go tools>folder options>view>check on all hidden files> check off hide extention........ & hide protected ........
Then after use your affected kinkstone flash driver
.Now you can see the many hidden file ,drag it and delete it or format the flash driver but your main pc should format and install the os again.
Posted on Nov 11, 2010
Why my san disk usb fash when i check its properties shows only 8mb out of 2gb and doesnt allow to be formatted
Whenever a computer tries to access a flashdisk, even for just retrieving the properties of the disk, a LED will flash.
Not being able to format your disk is another thing. If you've opened a file at this disk, Windows will prevent formatting. Best is to restart your PC, and than immediatelly start the formatting-process.
Oct 11, 2013 | Computers & Internet
Cannot open files on external hard drive
is it just the files or the hard drive itself you cant see
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
If you need more help with this post a reply
hope this helps
Jun 12, 2012 | Electronics - Others
I have files on the drive but it cant be seen. Ive tried showing all hidden files but it still doesnt work
click start control panel administration tools computer management disc management right click on this transcend drive select properties you will see a number of options general,tools,hardware,sharing make sure you have the correct setting in the sharing option this may vary depending which operating system you have
hope this helps
Feb 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
PC not recognising Iomega Prestige 320gb usb portable hard drive. I've connected it all up, disconnected, reconnected, rebooted the computer, but the drive is just not recognised and does not show up in...
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Mar 06, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
Cant use usb ports, the auto play doesnt come on. they only work when pluged in before i turn on laptop.
Hi there.
Try this:
Right-click the "My computer" icon > Properties > Hardware > Device Manager > expand "USB controllers" > right-click "USB root hub" > Properties > Power management > uncheck the box for "Allow the computer to turn off this device to save power"
Oct 03, 2009 | ASUS Computers & Internet
Pen drive is detecting but cant open it and in properties it shows unknown file system when i open it pc displays insert disk
maybe you need to go into windows settings and click hardware software detect, go threw the options and click the usb pen driver that it recommends, you might have to reset your computer, and it should work from there
Jul 02, 2009 | Audio Players & Recorders
I cant open my usb device
Those memory sticks are not hot changeable. Try the stick in a different computer if you can't open then it is bad, and it can change the drive letter for your cd-rom. Remove stick reboot computer and make sure the cd-rom drive has the right letter if not search help for how to change drive letter. Rember to always rignt on task bar then safely remove hardware or buy a hot changeable. Please rate nr mysleuth
Apr 28, 2009 | Computers & Internet
DATA INSIDE 32GB KINGSTON PENDRIVE CANT BE RETRIVED
I have worked through this problem. It is a new virus attack. you should get your antivirus updated and then get your drive cleaned. It surely will help you solving your problem.
Feb 20, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Recovery of data from flash usb drive
try formating it with other computer...
Sep 20, 2008 | Electronics - Others
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
93 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Mike
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
