Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Drive is not recognized
I used my Mybook Essential Edition 320GB for a few months in between both Windows XP and Mac OSX 10 without and kind of problems. I can't recall exactly when, but suddenly it was no longer recognized on either operating system. It will power on fine but instead of connecting the LEDs will just flash every second or so as if it's trying to intilize but never can. On Windows it never really stops doing this, but on OSX it will do it for awhile and then ask me if I want to try and repair the drive (I don't recall the exact application name). I don't really care to save the hard drive. I really just want to get the files off of it. Is there anything I can do?
  • Anonymous Sep 25, 2008
    My WD 500GB HD will turn on, but windows wont recanize it. The led isnt flicker its solid and if you feal the HD its making its normal constant hum and vibration.
Check if the Windows XP Security Updates are there on the Unit.
If these Update are present remove them & it should work Fine.
KB944533 - Cumulative Security Update fro IE 6 for Windows XP
KB943055 - Security Update for Windows XP
KB946026 - Security Update for Windows XP
Posted on Sep 30, 2008
Change mybook from one pc to another
You have to install the backup software on the new computer. Either download from WD to use what came with the MyBook. Attach the MyBook and find it in My Computer. If it is not there, you have to reboot and find the attached device. After Windows recognized the drive, the backup software will ask you for a new backup but just decline and reactivate the plan (actions/reactivate). That should do it!
Dec 05, 2011 | Western Digital My Book Essential Edition...
MyBook 2TB used as backup drive and connected via FW to other external HD. Had been powered off for a couple of months When powered up again, it does not show as a device (Mac OSX 10.6.4). Front light...
I would listen to the enclosure near your ear to see if you hear any "spinning up noises." Or if you hear "clicking" or "buzzing or beeping." Just to verify the drive is okay. It could have gone bad; being it is so new, it would be under warranty replacement. Also, connect the drive up to another computer in an effort to see if the interface is okay. There could be a problem with the usb controller inside the Mybook. HOwever, once you open it - the warranty is void. Lastly, you could send it to a data recovery company and see if they will diagnose it. Western Digital has a list of approved recovery companies on their website.
Oct 16, 2010 | Western Digital My Book Essential Edition...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
WD My Book 320 Drvive not recognized via firewire conncetion
if there is softwear uninstull it and renstull if not then check to be sure the board is pluged in
Nov 30, 2008 | Western Digital My Book Essential Edition...
WD mybook world won't work on mac?
Window and OSX - fun and joy.
Since you formatted a 1TB drive and it works fine in Windows, I have to concluded the the drive was formatted NTFS.
Here is the issue in a nutshell, OSX supports reading NTFS but have very limited write cababilities.
If you want both Windows and OSX to have full access to an external drive you should format it FAT32. The only issue then is that under normal conditions a FAT32 drive has a maximum size of 32GB.
I would partition the drive to have 1 or more FAT32 partitions and then have the rest of the drive NTFS.
Is the OSX version correct or should it be 10.3. If it is actually 1.3 it would mean you have the OSX Server edition that originally came out in 1999 and it may not have very good USB support - version 1.2 would only support 1 USB device.
Oct 16, 2008 | Western Digital 500GB My Book World...
Applications Intallation window did not run
setup.exe will help to install a wd anywhere backup software and also few other softwares which is compatible for windows not for mac
Aug 20, 2008 | Western Digital My Book Essential Edition...
WD mybook 500 GB
check for the file system.. from your mac go to disk utilities, file system might be corrupted
Aug 17, 2008 | Western Digital My Book Essential Edition...
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
185 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
