Question about ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard
WILL NOT BOOT
IS THERE A LETTER THAT I CAN HOLD DOWN TO RESET THE MOTHERBOARD TO FACTORY SETTINGS?
  • Anonymous Jun 20, 2008
    reseau
  • 144 Answers
REMOVE CMOS BATTERY & PUT IT BACK AFTER 10 MINS. BOOT THE PC AFTER NEXT 15 MINUTES..
Posted on Jun 23, 2008
The word demo how do I remove it from a AKASO tablet it's in big red letters?
Factory reset it,
Power off completely
2. then hold down the volume down button
3. holding the button press the power on button.
4. if done properly you should have several android boot options
5. select "Factory data reset"
6. Done
Note: if the volume down did not work, try the Volume Up button
Oct 16, 2017 | AKASO Tablets & eReaders
Tip
Reset a WYse WT3235LE back to Factory setting.
Hold down the G key when powering on and during the booting process to reset it back to factory settings. You can also do this in Control Panel under System.
NOTE: The G key trick is very picky so make sure you hold the G key before you press the power button and until it is booted. Also don't be frustrated if it doesn't work the first time.
on Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
How do you hard boot into recovery mode,volume down and power then release both and press again on lg screan dont do it both ways only factory reset
Do not forget to backup your phone’s data before doing a factory data reset. Here’s our guide.
Performing a Factory data reset restores your device to the original factory settings as it comes out of the box. It also deletes the data like installed apps, contacts, messages, images, etc. present on the internal storage. It does not, however, affect any data stored on the external SD card. Now here is how you can hard reset your LG G2/G3 from device Settings:
Tap the Menu key from Homescreen.
Select System settings> General.
Now scroll to PERSONAL.
Select Backup & reset option.
Tap Factory data reset> Reset phone.
Select Erase everything.
When the warning window prompts, tap OK.
Hard Reset LG G2 with Hardware Keys
If you unable to perform a factory data reset on your LG G2/G3 using the device settings for some reasons, you can try the hardware key method. Just follow the steps given below:
Turn off your LG G2/G3.
Now press and hold the Power + Volume down buttons simultaneously for about 8 seconds.
When the LG Logo appears, release and then immediately re-hold the Power button.
Release the Power key as soon as you see the ‘FACTORY HARD RESET’ screen.
Press the Power key to reset your device.
Press the Power key again to confirm factory data reset.
Wait till reset is done.
Boot LG G3 /G2 into Safe Mode
To fix an issue caused by a 3rd-party app, you can boot your LG G3/G2 into Safe mode and delete the suspect app. You can turn on Safe mode by following these steps:
Jan 06, 2016 | LG Cell Phones
How do I factory reset?
You can find in settings Factory Reset/Backup.
Turn device off. Hold at same time power + volume button up. When screen boots up release power button but continue to hold down volume up.
Nov 24, 2015 | Boost Mobile Kyocera Hydro Smartphone
I need to reset my Samsung tablet
Soft Reset
If the device is frozen or unresponsive, try pressing and holding the Power button for about 10 seconds. This should force the Galaxy Tab 10.1 to restart normally.
Hard Reset
A hard reset will set the device back to factory default settings and erase all data on the device. This is normally done when troubleshooting methods prove to be fruitless.
1. From the Home screen, select Apps in the upper-right corner.
2. Choose Settings.
3. Select Privacy.
4. Select Factory data reset.
5. Select Reset tablet.
6. Select Erase everything.
Access Recovery Screen at Boot
You can access soft and hard reset options from the Recovery Screen before you boot into Android. Just hold down the Volume Down button while turning the Galaxy Tab on. Hold it down until you see the menu.
Sep 21, 2013 | Samsung Computers & Internet
How to reset password on Sony Ereader. Daughter set it and forgot it. Unable to use. Thanks in advance, Tim
This is the only way if you can't remember the password.
Here's the procedure for resetting the device back to factory default:
Note: Performing this procedure will delete any content you have stored on the Reader.
1). With the reader off, using a paper clip or similar device, press in and hold the Reset button on the back of the unit for 5 - 10 seconds.
2). Release the reset button and power on the reader.
3). While the reader is booting, press and hold both the Volume Up and Mark Buttons. Continue holding until you see a screen asking you to confirm that you want to reset the device back to factory default (Press Button 5). Note: I had to hold down these buttons for about 60 seconds to get the confirmation screen. Also about half way through this process, you should see a blue light flash momentarily around the lower left Page button.
4). After you have confirmed you want to set the device back to factory default, the reader will turn off. Turn the unit back on and it will go through its initial start up which takes a minute or two.
Hope this helps, Thanks for using FixYa
May 15, 2011 | Computers & Internet
I would like to reset it back to factory settings thank you
During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart also click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps
Apr 08, 2011 | Computers & Internet
Privacy lock hiptopq700 forgot how do i fix it ??
Hi.
You can do an hard reset. This will reset all settings to factory and erase phone memory. It won't delete data stored on SIM:
1.Remove Sim card and memory card
2.press and hold down the "R" button
3.Insert battery Into the phone while you keep holding R button.
4 When the display comes on release the R button and allow the phone re-booting
5. Put the SIM back into the phone.
Other way to release the lock is by holding down the letter L button and the Menu key at the same time. In this case the phone will not get reset, but the lock should temporarily release access to the menus. The function availability depends on settings. You can give it a try before resetting the phone.
Regards.
Ginko.
Mar 22, 2011 | Cell Phones
Asus A8JR Won't Boot
Have you made any hard ware changes?memory upgrade hard drive?
You can try holding down the f12 key while booting up.This will bring you to the cmos or bios page.
once there try setting system back to factory default or optimal settings.
www.asus.com
good luck.
Jan 10, 2010 | ASUS A8N-E Motherboard
ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard Logo
66 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
