Question about Microsoft Windows XP Professional for PC
When i turned on our PC, after POST it proceeded to windows and it keeps on loading.. the screen display does not change.. is the OS being corrupted?
  • Microsoft Master
  • 27,725 Answers
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Nov 11, 2010
Acer 4320 Screen turn blank when it load Windows.
press fn button and with up-arrow increase brightness ,,, in windows open display settings by right clicking on the desktop (intel or nvidia properties ) acer 4320 could have nvidia or intel ... increase the brightness and the contrast or load the default settings ,,, use external monitor if need ...
Mar 07, 2012 | Acer TravelMate 4320 Notebook
Computer is not loading..black screen keeps coming with the message input not supported..how can i turn my computer on normally.it loads on safe mode.
Input not supported could be the screen having problems. It loads in safe mode so the display driver is corrupt or set to a too higher resolution for your screen.
Adjust it as required.
Jan 08, 2011 | Computers & Internet
How do i fix my computer with a blue screen that keeps shutting it off?
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
Post your OS please!
Oct 01, 2010 | Computers & Internet
My laptop only turns on as far as windows logo screen then black screen
that could be system glitch in windows. try logging in to safe mode and perform system restore. choose restore date where your computer is working perfectly. thanks
Mar 28, 2010 | Computers & Internet
I turn on laptop and i get message saying windows couldnt start and to either select start normally or to load windows repair manager i did this but it couldnt fix it.so i tried using alt F10 for restoring...
It looks your Win OS has become corrupt....
If you have a install Windows disk...
then insert that in the CD drive and start the PC
when the system boots from the disk and Win loads
chose the option repair my Windows....
then follow on screen ins
if that does not help...i am afraid you may have to re-install the Win OS....
for full details visit my website...(has all required details and links to tools for re-installing Windows)
www.sureshayyar.110mb.com
all the best
let me know if that helped...
Mar 11, 2010 | Acer Aspire 5100 Notebook
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
May 22, 2009 | Compaq Presario R3000 Notebook
Compaq Presario V6000, keeps rebooting, blank screen, and no post beeps. Replaced ram, battery, and power adapter. There is no hard drive light. I think it is a hardware problem, because it will not boot...
If your pc reboots just after post my first place to look is to reseat the hard drive and see if that makes a difference. If it doesnt you could try and repairing your windows operating system or doing a system restore. If the os loads sucessfully then i would say you had a corrupt boot file maybe from a virus or a failing hard drive. I hope this helps
Mar 24, 2009 | IBM ThinkPad T40 2373 Notebook
Computer will not boot up. I have tried to boot up in safe mode, normal, safe mode with prompt command...nothing works, just goes back to the normal start up screen and keeps doing the normal start up over...
It looks like you're encountering an endless reboot? Here's what to do to find the actual error message.
  1. Turn on the computer, and press F8 after the POST screen but before Windows attempts to start to access the advanced startup options.
  2. Select "Disable Automatic Restart On System Failure" and press Enter.
You should now get a blue screen with an error message and error codes. Please write these codes down and report back.
Mar 24, 2009 | HP Compaq Presario SR1830NX PC Desktop
Toshiba Laptop unable to start but only displays post screen
ur OS has corrupted two reasons for that
1. due to virus, malware spyware, etc
2. Hard Disk is getting weak wants replacement
solution first try to re install the OS if u find it difficult to do so then my friend ur hard disk needs replacement
factory reset procedure
Toshiba: BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
pls rate me FIXYA if i fixed ur problem
Mar 01, 2009 | Toshiba Satellite A135-S2276 Notebook
Microsoft Windows XP Professional for PC Logo
15 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
