Question about Amana ACE208 Convection/Microwave Oven
Hello I own an Amana ACE208 oven, it display´s ERR2 every time the oven is in standby mode (5 seconds after it is pluged and five seconds after it is switched off) and I can´t switch it back on unless I unplug it, plug it again and quickly press the on button, while the oven is on it operates fine, any thoughts on what the problem might be?
5 Suggested Answers
MicrowaveSvc
  • 9156 Answers
SOURCE: My display reads -SE-
-SE- error means you have a shorted keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 02, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: my amana ace208 convection oven
The transformer has failed.
You can order one here if you think it might be economical to repair.
Posted on Aug 19, 2008
MicrowaveSvc
  • 9156 Answers
SOURCE: Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Posted on Feb 02, 2009
SOURCE: Amana ACE208 doesn't work with a message 'door'
The door latch receiver has a spring action lever (inside) that is made out of plastic and cracks or wears through. You need to remove the cover and remove the two screws holding the door latch receiver. Now you can switch the top and bottom piviot switchs, putting the top one lower and the lower one on top..make sense? you"ll understand when you see it.
Posted on Mar 02, 2009
Microwave works but does not cook (does not heat up). Everything else seems to work properly.
hello,
what this means is that there have been a disconnection on the wire of the element (heater)
what you need to do to fix up the problem is to unscrew the oven then trace the wire down to the element power point and fix it back to it position
please make sure all form of power supply is OFF when carry out this function
Good lock and thanks for using fixya.
Jun 03, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My house lost power earlier today, and now my microwave is not heating the food, and has a lower case "d" in the display after the time. Any suggestions?
It is in the demo mode. To turn off here is what the manual says:
The microwave oven and Timer must be off. Touch and hold Timer Off or the number 3 pad (depending on model) for three to five seconds (depending upon model) until two tones sound and “d” or "Demo" (depending on model) appears on the display. Repeat to turn off and remove “d” or "Demo" icon from the display.
May 10, 2010 | Whirlpool GH7145XF Microwave Oven
Ace 208 comes up with "hot" in display amana tech say not possible no code like this
Hello I´ve repaired a couple of ACE208 with hot message in the display. The problem is in the convection fan located on the back of the oven cavity, turn the oven on and quickly open the door and look inside to see if the fan is spinning (slowing down, the fan stopps when you open the door but you can see it slowing down) if it is not spinning the supporting screws of the fan sometimes loosen up causing the fan to hit the oven walls preventing the fan to spin freely -probably before the problem started to happen you could hear a loud noise- the fan can´t move the air throgh the warming elements causing them to overheat hence the hot message. The fan motor rarely fails so all you need to do is remove the stainless steel cover and the back black cover and tighten the mounting screws of the convection fan and clean it if it´s dirty. Hope this helps, both the ovens with hot message I have repaired get the green tag just by doing this or replacing the motor, I have no knowledge of other problems that may cause this.
Dec 02, 2009 | Amana ACE208 Convection/Microwave Oven
C5 error on amana dq22hs
A CS error means oven senses to much current or not enough. The problem could be a burnt wire on the door switch, or mag themals. It could also be a ploblem with one of the HV compents. You should have a tech check it out due the the dangerous HV system.
May 01, 2009 | Amana ACE208 Convection/Microwave Oven
My amana ace208 convection oven the transformer smokes when asked for power
Aug 19, 2008 | Amana Microwave Ovens
Microwave oven ACO1860AS
just aquired one just like it for free. they said no heat. took the outer cover off. about 12 screws. pull the main fuse and test it with a continuity tester.thats probably not it if the lights work. its either the magnatron (toshiba 2m248j(gs) or replacement part amana 8205460. mine was a coroded magnatron connection.unplugged it and pluged it back in. heats fine now. if you left it on with nothing in it for any length of time you blew the magnetron. universal magnatron replacements on ebay are $25. 4 screws and a 2 prong connector.
Aug 11, 2008 | Amana ACO1860 Microwave Oven
Feb 26, 2008 | Amana ACE208 Convection/Microwave Oven
Volume control
no there is no way to adjust the alert they come already factory set.good luck
Apr 16, 2007 | Amana ACE208 Convection/Microwave Oven
Amana ACE208 Convection/Microwave Oven Logo
54 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
