Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Refrigerator hi i will like to get some help with my side by side refrigerator kenmore i cant not find my ower manual and now i need to level my doors because now they are too together
  • 76 Answers
Look at the hinches of the doors,there should be 2 bolts on a hince...
Loosen the top ones if its hanging at the top, or the bottom ones if its hanging at the bottom.
Just get some one to hold the door in place then tighten the bolts.
Good luck...
Posted on Sep 09, 2008
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
Freezer door is not closing equally
hi there.sorry i cant help u with the model no: but in general doors not aligning or closing properly is usually due to 1-unbalanced fridge.level it prop.try raising one corner at the time and c.2-check hinges pins and bushes and replace acordingly. good luck.hpe this helps.Ali
Aug 23, 2012 | Kenmore Refrigerators
My kenmore elite french door fridge is leaning back by a few degrees. ive tried to adjust the legs on the front but no luck. are there any legs on the back? i cant see them. the leaning back causes my...
there should be two set screws in the front of the refrigerator behind the long vent cover remove it and the screws should be in each corner. take a socket that's the right side and turn them and it should level the frige.
Dec 17, 2010 | Kenmore Refrigerators
How do you adjust a door on the refrigerator. Our
under the door ,on the hinge side, is a bolt to adjust the floor level.using a level, make sure the unit sits square, before raising with blocks all round.
Mar 31, 2010 | Kenmore 64802 Top Freezer Refrigerator
How do i level my Kenmore refrigerator model number 25374824406??
You should level the refrigerator on left and right side and the front door side the top leaning just a little to the wall behind the refrigerator. This keep the doors from swinging out or not closing well. Never level a refrigerator all the way around, Thanks, Sea Breeze
Apr 14, 2009 | Refrigerators
Need to level my kenmore 25 cu side by side-don't have a manual
take of your front kickplate you see the leveling screws on either side
Mar 15, 2009 | Refrigerators
Kenmore elite side by side freezer door higher
Check the lower mount bushing. These are nylon and wear/break easily.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by side door
Depending upon your model it could either be a sagging door hinge (requires replacement) or the fridge my not be level. If you remove the toe-kick panel there will be a couple of bolts which are used for leveling ( they should be indicated as such or shown in your owners manual). Alternately there may be screw type legs which are used to level your fridge.
The seal should improve once the doors are properly aligned.
Jul 25, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
MZD2766GES: How do I level the doors?
The door needs to be level, or the whole side of refrigerator. Pull off black strip at bottom front, there should be screws on either side to level the fridge. goodluck
Nov 09, 2007 | Maytag MZD2766GES Side by Side...
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
