My acer laptop adapter's green light is blinking... therefore it's nt charging...............
    Guru:
  • 832 Answers
Thanks for using FixYa!
Please check the following:
1. Check your power supply, make sure it is connected properly.
2. Check your ac adapter from and to your laptop and outlet.
3. Check your battery if its properly installed.
If you need further assistance, please let me know.
Regards,
fossildude
Posted on Nov 11, 2010
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
Battery indicator on my acer aspire 5517 laptop is blue what does it mean
Acer Aspire 5517 shows BLUE light when fully charged.
Start it and check battery indicator (tray item) will probably say
plugged in fully charged (with adapter plugged in)
Dec 07, 2013 | Acer Aspire 5517 Laptop
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Acer aspire 5750 charging problem
The solution to your problem lies in one of the following three areas:
Your charger is faulty and is therefore not able to pass power to your laptops battery.
The charging connector on the laptop has come loose from the contacts. Therefore a bad connection.
Your battery is faulty.
If you are sure that your laptop charger is dead and you are in the market for a new one, try the following one:
Replacement Acer Aspire 5750 AC Adapter 90Watt 19V 4.74A
Oct 30, 2012 | Computers & Internet
Sir i have acer 4720Z series laptop. when I plug in the power adapter it show adapter light green. when adapter pin connect the laptop then light show blink and laptop not charging.
Your laptop battery seems to be broken.
To be a 100% sure, can the computer run on only battery?
Try to have the computer plugged in to the charger for a couple of hours without starting it.
Feb 28, 2011 | Acer Aspire 4720 Notebook
The green power button and orange battery light keep blinking. is it time for a new battery?
maybe. isolate it first. try using new battery. if the blinking lights stops, then it needs new battery. if the blinking do not stop check the power adapter maybe that is the defective. it did not give enough power to charge the battery.
Jun 03, 2010 | Acer Aspire 7520-5185 Laptop
My Acer Aspire 5920 is not booting up. When the power supply is plugged into the wall, its green LED is solid. As soon as I plug it into the laptop, the light starts to flash. When connected to the AC...
Your motherboard is probably shorting out your A/C adapter, you may need a new motherboard. With a Dell, the A/C adapter light will be green when plugged into the wall but as soon as you plug it into the PC the green light goes off. Which means that the Motherboard is shorting out the A/C adapter...
hope this helps
Sep 08, 2009 | Acer Aspire 5920-6727 Notebook
Acer laptop question.
Your battery may be dead to a point that it cant boot your system. Try to charge it for a day or so then try with the adapter, and battery
Dec 05, 2008 | Computers & Internet
Does not turn on
if your laptop not charging better change the ac adaptor to charge but if your laptop not booting but the charger charge the the laptop the problem is you motherboard just try to reset you CMOS then try to boot again
Apr 06, 2008 | Acer Aspire 1690 Notebook
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
