Question about Hilti 284228 UH 650 Universal 1/2" Hammer drill
The drill is leaking oil - Hilti 284228 UH 650 Universal 1/2" Hammer drill
  • 7,733 Answers
As my knowledge drills not use oil just grease in the bearings.But if you need to service and the drill is not too old and the repair is not cost too much you can find parts at Hilti Online or by your self using the Hilti Manuals.
Posted on Nov 12, 2010
Battery leaks oil while using or charging, why?
The battery does not contain any "oil", and should not be leaking any fluid whatsoever. Since it is doing so during use or charging, it points to leakage caused by slight thermal expansion under load. This is bad, as these are Li+ cells. If you are sure the leakage is coming from the battery, stop using it, seal it in a safe container, and dispose of the battery properly. To verify it is the battery, check and see if another (NEW) battery has this same "issue" under your normal usage.
Sep 02, 2015 | Drills
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I BOUGHT A PUMPSET ABOUT TWO WEEKS AGO AND I CHANGED THE OIL AFTER RUNNUNG FOR THE RECOMMENDED 50 HOURS WITH LOW SPEED BUT YESTERDAY IT WENT OFF AND ITS LEAKING OIL ADVISE ME ON WHAT TO DO.BECAUSE AM...
If there is a leak in the pump then please check if the leak had come from the drain plug or the inlet. If the leak is elsewhere it is important to get in touch with the dealership and get explanation.
Sep 21, 2010 | Powermax XP650WP Portable 3' Water Pump...
Brand new Hiyachi DH24PC3 leaking oil from chuck on first use while using hammer only chisel application - is this due to overheating ?
Hi, these impact drills need greese to function properly and some modles leek more than others. As its new you could ask for a new seal, as this is what is allowing the oil to leek. Hope this helps
Jul 05, 2010 | Hitachi 3/4", Variable Speed Reservible,...
Hilti te 15-c i have a oil leak behind the chuck.
It depends on where the leak is. if you email me I can send you an exploded diagram of tis machine. This will give you an idea of how to take it apart.
paul@wysehire.gi
Apr 09, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Oil leaking from gear box on hammer drill
Where is the oil leaking from. By the chuck, or the selector knob, or is it leaking from where the gear housing meets the motor housing. I could be one of 3 things. There is a seal between the two housings that could be damaged, not likely though. There is an oring on the selector knob that can get worn, and there is a sealed bearing on the spindle that should not let any oil through. There should not be any oil in this tool for lubrication. Grease is used in this tool for lubrication. If you are getting oil or a liquidy type substance coming out it is more than likely the grease has broken down and needs to be replaced.
Oct 14, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
HOW DO I FIX AN AIR LEAK FOR A BOSTITCH MODEL N79RH?
were is the leak, all air tools need some TLC occasionally . Try putting some air tool oil in it and try it again, if this doesn't work you probably have to change a few o-ring, they break down after awhile especially if it hasn't been used in awhile .
Aug 13, 2009 | Stanley Bostitch HP118K 23 Gauge Headless...
Oil leak
First check the oil level. It should not be overfilled. Is the compressor level?
If above is all OK, change the oil with the recomended ok. Check the IR web site for an approved oil. It is important that the right oil is used.
If you still have a problem it sounds like a time for piston rings.
Good Luck
Feb 22, 2009 | Ingersoll Rand 231C-KS - 1/2" Super Duty...
Throwing oil
i really dont worry about the leak near the shaft because with out the oil in the shaft there is a possibility that the shaft can jam. even dewalt new hammer when you purchase it come with the grease/lube like a toothpaste size. this is to lube the bits for the purpose the bit/shaft can move freely & also can hammer freely. our you can do is to dis-assemble the front end sleeve & remove the excess oil.will i agree weather can also change the viscosity of the oil. varsol cleaner can do the trick available at walmart.
Oct 15, 2007 | Bosch HCBG500, 5 Pc Industrial Hammer...
Hilti 284228 UH 650 Universal 1/2" Hammer drill Logo
510 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
