Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
Not cleaning at all - most dishes end up being washed by hand afterwards
My Tecnik built-in dishwasher rarely cleans anything properly.  We usually end up having to unload it after a wash cycle and do everything by hand.  We have taken all the filters out and cleaned several times, run cleaning cycles with specialist cleaners, made sure the salt and rinse aid are topped up etc., tried different powders/tabs - but nothing works.  We still have the same problem.  There are no problems with the actual running of the dishwasher or draining etc.  It simply does not clean.  I am lucky if 2 or 3 items come out clean enough to put away.  Any help would be appreciated as very frustrating problem.
  • shoshi-g Aug 27, 2008
    I've got the same problem, and have tried all the things Sara has tried.  We were on the verge of calling in someone, as we have been handwashing for 3 weeks (and we have a large family!).  Now - does anyone know how I can tell if the arms are rotating or not, or if it may be a pump problem?  Many thanks, Shoshana.
  • pencil222 Jan 23, 2009
    i have the same rpoblem adn have tried everything - did you manage to solve it - or did you need to get in a technician
    thanks penny
    Genius:
  • 1,036 Answers
Hi there!
You've done the basics, so we'll treat it as a fault due to wear.
When running, do you hear the spray arms rotating - about twice a second?
If the water is actually reaching the dishes, bur the arms are not rotating, you may need replacement spray arms.
If the water is not even reaching the dishes with any force, The circulation pump may be faulty and needs replacement.
Hope this helps you.
Posted on Jun 17, 2008
Dishes not cleaning after full cycle running
Your screens are plugged with food residue in the bottom of the unit. clean it out. You can use 1 gallon of white vinegar for your wash after you clean the screens. Start your washer to fill with water but after the water starts, open your door and pore all of the gallon in the unit. Let it now run for 4 minutes and stop it by opening the door. Leave the door slightly open for 1 hour. close the door and let the cycle continue for 4 more minutes. open the door and repeat it a couple of more times. Let it sit all night with the vinegar in it and in the morning - close the door and let the cycle continue to the end. This should help soften and clean out the food particles in the unit. You can repeat the process and get a better cleaning then too. All the scale should be off your dishes now.
Jan 08, 2014 | Frigidaire Professional Series 24 in....
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
Dishes not cleaning
There is dirt floating around in there that you cannot see...replace it and you will be washing again...
That problem can have many and varied solutions...I have tried to put together in this tip the most common and easiest to checkout problems. For many of the spray arm problems the solution will be here, but it would be impossible to cover every possible problem in any answer with out actually being able to hands-on disgnose the problem....
Dishwasher2_bing.gif Spray Arms not Spinning
http://www.fixya.com/support/r4817172-dishwasher_spray_arms_not_spinning
heatman101
May 30, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishes not getting clean! and the soap dispenser rarely opens as it should
make sure filter at the bottom of the unit is sparkling clean. dishwashers do not make miracles...clean excess food remains before putting your dishes in the unit. Use good soap. The 5 in 1 finish are usually very good
Mar 07, 2010 | Ariston Technologies LL64WNA Built-in...
Whirlpool Quiet Partner 2 dishwasher
You need to clean the 2 rotors properly and that also includes the sieve. Make sure once the dishes are stacked, the rotors must turn freely by hand.
Sep 16, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
The Tecniks dishwasher seems
Hi.
Try running a cleaning product to clear the rear pipes of any grease deposits.
If this does not work, check rear pipesare not kinked.
Hope this helps.
Apr 06, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Motor problem??
have you checked the pump / motor belt?
Dec 18, 2007 | Tecnik TDW2677 Built-in Dishwasher
Water not hot
Dishwashers are suppose to be hooked up to hot water. If you had hotter water it would clean just fine. 120 deg or more!
Nov 01, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dishes won't come clean
If you have dishes (typically cutting boards or really tall dishes) that block the dispenser door from opening, the water cannot wash out all the detergent during the wash cycle. Check to see that after loading the dishes, your detergent door has clearance.
Aug 26, 2007 | Frigidaire 24 in. FDB126RB Built-in...
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
416 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
