Question about MSI Computers & Internet
In msi ms 7071 motherboard sata hard disk doesn't show in bios but sata dvd writter shows in bios why? and how to solve this problem.
Smooth_Gecko
  • 125 Answers
SOURCE: MSI MS-6590 Hard Disk
Up to 160 GB is supported by the KT4 Ultra (MS-6590)
Posted on Aug 01, 2007
Nic61
  • 1073 Answers
SOURCE: MSI motherboard - SATA Hard Drive
Hi again!
Here is the manual, the drivers and everything else there is abut that mobo of yours.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=152
You need to change the settings in the bios, the settings how your motherboard reads the disks. You will find it in the manual-
Good luck
Nic
Posted on Mar 16, 2009
  • 20 Answers
SOURCE: my msi ms-6590 doesn't detect my sata hard disk, i
You need driver for the Promise 150 controller for Serial ATA RAID . Link http://www.tomshardware.com/reviews/athlon-boards-kt600-chipset,676-7.html
Posted on Nov 22, 2009
SOURCE: msi ms 7071 motherboard driver
i need ms-7071 all driver
Posted on Jan 28, 2011
SOURCE: hello my mother board is (PM8M2-V
yes is supported 500 gb hard disk
How can i install my 500 gb sata hard disk, in bios i din't found any sata settings...plz help
There are no SATA settings in BIOS for most systems. As long as your motherboard has SATA connectors, the BIOS should recognize that the drive is installed and then you use Windows to format it for use.
You should see the drive listed in the drive section of the BIOS after you have connected both cables for it (power and motherboard).
Dec 09, 2014 | VIA Msi Ms-7071 Ver:1 Pm8m2-v Socket 775...
I am not able to detect sata hard disk in msi mother board
Your model K8MM-V motherboard does not have a SATA controller only IDE disk controllers and therefore it cannot detect a SATA hard drive.
To install a SATA hard drive on this motherboard you need to purchase a PCI SATA disk controller and install it on the PCI expansion slot and then attach the SATA hard disk to this SATA controller.
Aug 21, 2010 | MSI K8MM-V Motherboard
How to configure bios to read sata hard disk
To configure your bios to read sata hard disk follow this Steps:
1. Power on the computer
2. Keep pressing the delete keys until bios utility will show
3. Go to the advance settings
4. Find the Sata Mode and then change it to IDE:
5. Save changes and Exit
Hope this could help.
Sep 27, 2009 | MSI K8MM-V Motherboard
SATA PORT NOT WORKING
The universally accepted HDD is the IDE, why are you trying to make it with a SATA? With a IDE you will avoid all the troubles. Yes! SATArequires a change in the BIOS. We can help you do the change, if you know how to do it. Playing with BIOS can cause the entire MB to burn out and destroy itself.
May 18, 2009 | MSI : MS-7061-020...
Dvd writter not working
if the device is set up as a master and not a slave device it may be interfering with the hard drive. check the jumpers on the back of the device. If it's plugged into the same cable as the hard drive it must be a slave device. Otherwise, check your bios upon bootup to see if you it's trying to boot from the device instead of from the hard drive.
Nov 29, 2007 | Samsung WriteMaster SH-W162C DVD?RW Dual...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
629 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
