Air-O-Swiss U7142 Humidifier
Problem for Air-O-Swiss U7142 Humidifier
How to clean air o swiss humidifier
By phillipwoode on Jun 17, 2008
I am waiting for ezcal is there any other way to clean my air o swiss hlumidifier?
Same Problem
Mar 06, 2009
-   air flows slowly but no mist comes out. What is the solution? -   prausyk
Solution #1
posted on Dec 03, 2008
Somewhat Helpful)
JoJoDaClown
Rank: Apprentice
Rating: 75%, 1 votes
Any bathtub cleaner will work so much as you do a good job cleaning then rinsing. Be careful not to get the humidifier wet anywhere other than the basin that the water goes through.
Was this helpful?
Yes
No
Popular Solutions for Air-O-Swiss U7142 Humidifier
Questions and Unsolved Problems for Air-O-Swiss U7142 Humidifier
Do you recommend Air-O-Swiss U7142 Humidifier?
Answer
Answer
Leaking. The white plastic circular ring in the base unit is cracked. This is part of the... (More)
Answer
When if fill the water tank with water and place it on the base the base fills up and leaks between... (More)
Answer
Air flows but no mist.
Answer
hi - i have a problem with my 7142 air-o-swiss humidifier - can you help?
Answer
i pushed the button, the signal shows the heat feature on, but the heat is still the exact same temp... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air-O-Swiss U7142 Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 2528
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
