Cars & Trucks Logo
Posted on Jun 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Merc vito head
Need to take the head off my vito as i have 2 glow plugs stuck and need drilling out, i have no work shop Manual and cant get 1 for no love or money help , johno
Anonymous
Level 3:
Genius:
  • Master 1,036 Answers
  • Posted on Jun 17, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1036
Questions
6
Helped
412180
Points
3010
Hi there! There is a Book sold by:motorbooks-co-uk - "Pocket Mechanic for Mercedes-Benz Vito and V-Class to 2000: 2.0 Litre 16V Engine (111 Engine), 2.3 Litre Diesel and Turbo Diesel with Injection Pump "
Author - Peter Russek Uk - £14.25
Haynes don't do a manual yet, but this may give you the right information you need.
Hannes Marais
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 30, 2015
Hannes Marais
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1165
Points
How can I found the vito 115cdi 2008 16v camshaft timing marks
1helpful
My vitto 115 electrics does not work after charging the battery
Try the Benz Forums. Sounds like overcharge spike.
Vito 115 electrical Gremlins ' Mercedes-Benz Owners' Forums
https://forums.mercedesclub.org.uk > vito-115-electrica...
Jan 20, 2014 - My 639 115 vito that I've had almost 3 year and been totally reliable has suddenly started playing up. I parked it up for a couple of months ...
no power vito 115 ' Mercedes-Benz Owners' Forums
May 28, 2006
Merc Vito electrical issue ' Mercedes-Benz Owners' Forums
Jul 26, 2018
Vito 115 CDI COMPACT SWB indicators and wipers not ...
Nov 6, 2020
Vito 115- start probs?!! ' Mercedes-Benz Owners' Forums
Mar 3, 2008
More results from forums.mercedesclub.org.uk
vito 115 tow bar electrics ' Mercedes-Benz Forum - BenzWorld
https://www.benzworld.org > ... > V-Class
Aug 30, 2019 - Hello everyone, I'm just about to swap my 108d for a 06 115. I need to fit a tow bar and twin electrics to the new van. Does anyone have experience of...
Vito 2004 wiring diagram ? ' Mercedes-Benz Forum
Jan 8, 2017
Vito 115cdi 2006 electric windows removal - BenzWorld
Dec 24, 2010
Vito 112 CDI Electric Windows ' Mercedes-Benz Forum
Mar 22, 2011
Vito 115CDI Won't Crank/Start - ECU fault?! - Please advise...
Jun 14, 2012
More results from www.benzworld.org
buy Electric parts for Mercedes-benz Vito bus (w639) 115 CDI in our ...
https://allparts.me > mercedes-benz > electric parts
Take a look at our selection of Electric parts parts for Mercedes-benz Vito bus (w639) 115 CDI. We provide a guarantee so that you can order with confidence ...
Vito 2002 glow plug light sometimes stays on?
Maybe sticky relay, the relay times out when the glow plugs reach temperature, if the relay is sticking then light will stay on and so will glow plugs if they have not burnt out
P1954 + P1955 2007 merc sprinter what do they mean
P1954 automatic glow time control module 2 electric circuit malfunction. P1955. Glow plug control module 2, to pcm circuit range/ performance. You have to replace the the glow plug module and maybe glow plug also
Glow plug brocken off in head
Are the threads of the glow plug assembly broken off in the head?
Any way to get a hold and turn?
If so you can try to heat it with a torch or penetrating lubricant.
If there is no other solution but to drill and tap I would take off the head and take it to a cylinder shop, have it machined and replace the head. I know this may seem like a task but if you have time and another vehicle its a lot cheaper to do it yourself. Get a book for your vehicle that shows the repair and replace procedure and torque specks.
Good luck--
I hope this helps!
Hi expert boss..i have a mercedes benz vito 108 and i cant start it..i have a edc light on the screem ..ca you hello me?
EDC LIGHT SOUND LIKE GLOW PLUGS NOT WORKING, COULD HAVE FAULTY GLOW PLUG RELAY OR ECM PROBLEMS.COULD HAVE FAULTY COOLANT TEMPERATURE SENSOR.BEST TO LET GARAGE CODE SCAN FIRST DONT BUY NEW PARTS UNTIL SYSTEM CHECK OUT FIRST.
Serpentine belt diagram for mersedes vito cdi 109
We do not have this application in our catalog
2helpful
Merc vito 07 van right side electric motor works but window stays stationary
The motor is either stripped internally or the track has broken. The only way to verify which is the cause is to take the panel off the door. If the window is stuck in a position other then all the way down it is most likely a striped motor.
3helpful
3answers
Change glow plugs on mercedes vito 2.2 cdi
This is a Diesel van -- Glow plugs are not too terribly hard to replace, and as long as you disconnect the battery first when replacing them you shouldn't have a problem (except for maybe some access issues - It is a Van) - So yeah, if you can get to them - go for it - you won't hurt anything (Provided you do not cross thread anything) and you can always stop or put them back if you feel uncomforttable...Best of luck...
Glow plug end stuck in cylinder head
If the piece with all the tread's on it has screwed out then a punch will put it out if their are some of the tread's left on the piece broken in then you will have to bore it out. You will need to remove the cylinder head regardless as the piece stuck in when you remove it will fall into the cylinder and the only way to get it out it through the cylinder head.
Speakers in the passenger compartement of merc vito 109cdi
Read the manual for the radio or go onto the makers site and get one
In there it will tell you about setting the Front to Rear Fader which puts the sound into the car where you want it.
At this time you have got the control set to direct the sound to the front only
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
