Question about Hotpoint TDC32 Electric Dryer
My ctd40g tumble dryer has recently started smoking and the drum is no longer spinning, can you help?
  • 320 Answers
Your dryer motor might been short circuited and the motor needs to be rewind or replaced.
Posted on Nov 11, 2010
TD514 TUMBLE DRYER POWERS UP OK DRUM DOES NOT SPIN TURN DRUM SLIGHTLY WILL START TO SPIN
Hi, Motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 09, 2011 | Miele T8005 Tumble Dryer
Hotpoint Tumble Dryer CTD40G At the end of a cycle the on/off light was flashing plus Time Delay and High Heat lights were illuminated. The drum rotates but the clothes remained wet. There is no obvious...
that isn't a good model number open the door,look around the opening where you put the clothes in and you'll see the model number,you could have a bad thermal fuse or another t-stat is bad,you have to get in there with a meter and check out the parts for continuity
Dec 16, 2017 | Hotpoint Dryers
GEW9200LW1 DRYER TURNS ON BUT DOES NOT SPIN
Well first of all you may check out the Door Switch if it's defective then your dryer is not able to spin, it may interfere with your dryer drum's ability to tumble. Test your dryer's door switch. If it is no longer functioning than you need to replace it. you need a multimeter to check it. Post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Whirlpool GEW9200L Electric Dryer
Dryer has power does not spin shuts itself off in a few seconds
Good Luck!!
Jan 25, 2011 | Amana NGD4500VQ Dryer
LER5636P Electric Dryer: WILL NOT SPIN...
Good Luck!!
May 18, 2010 | Whirlpool LER5636P Electric Dryer
My dryer stopped spinning and will not start again. I have been hearing a small screw tumbling inside when dryingbut its been like that for some time and never stopped spinning.
It sounds like that screw has finally done its damage and got trapped in the end of the drum the drum would normally have to be removed to free it off.Can you turn the drum by hand if so then it would be advisable to check the drive belt if thats ok then it may be the motor or the capacitor of the motor.
Hope this helped.
May 09, 2010 | Dryers
Tumble dryer makes whine noise but doesnt spin
Sounds like the drive belt has gone,and the noise you can hear is the motor going round.
The red glow you can see, will be the heater element glowing..
To check the belt, remove top cover, and you will be able to see if the belt is on or not, if you can see it round the drum, try to lift it up, if it has not broken,then you will not be able to remove it, and that means the motor or drum could be siezed, try to turn the drum by hand, it should be fairly stiff to turn, but not that stiff that you cannot turn it at all.
Please rate my fixya solution.
Thanks.
Feb 01, 2009 | Hotpoint NWXR473EV Dryer
I don't have any heat from my hotpoint aquarius ctd40G Tumble Dryer. I have cleared all the fluff from the condenser unit and unplugged the mains and tryed it all again but we still do not have any heat...
Remove the rear cover and you will see the element and stats, you will need a meter to test them.
Pull one wire off each thermostat and with a meter that beeps, test across each thermostat, if they are o/k, then the meter will beep,
if no beep then no good.
Replace all heater stats, even if only one has gone
If the stats are o/k then you will have to check the heater, this is more involved as it entails removing the top cover and left side panel looking at the dryer from the rear.
Unplug the heater lead, and again test with meter,if element o/k, then prob is timer or main pcb could be faulty, it really does get quite involved.
There is also a thermistor at the front of the dryer, that is part of the heating circuit.
Plz rate my solution.
Thnks.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Electric dryer not spinning
Good Luck!!
Dec 04, 2008 | Dryers
Hotpoint TDC32 Electric Dryer Logo
174 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
